Storing Caravan (taking load off the wheels)
Submitted: Wednesday, Oct 04, 2006 at 12:56
ThreadID: 38256 Views:7421 Replies:8 FollowUps:10
I need some information please. When we store the caravan for a period of time, we want to take the load off the wheels. Unfortunately we are not able to get around one side of the van and have to crawl under it.
Is there a way to jack up the four wheels of the van when in a tight spot, can the four wheels be raised at the same time (pehaps hydrolicly?) Is there anything on the market?
Ta Maria
Reply By: flappa - Wednesday, Oct 04, 2006 at 14:33
Yes , there is something on the market.
Not sure exactly whats its called but , they are wheels that take the place of the existing wheels. Its mainly used for lowering the van to fit into tight places , but it would also work if you want to take the wheels off.
the question though ?
How long do you need the wheels off for , days/weeks/months/years ?
Im pretty sure its shown that unless you leave the wheels/tyres in one place , for years at a time , then it doesn't really effect them. Days/weeks/months doesn't really matter
AnswerID: 197797
Follow Up By: Member - Maria P (SA) - Wednesday, Oct 04, 2006 at 18:00
Hi Flappa,
Thanks for the reply. We are stillworking and not able to get away often and were worried about the tyers getting a flat area.
Cheers, Maria
FollowupID: 456384
Reply By: NRE - Wednesday, Oct 04, 2006 at 15:58
Maria.
I think the reason for taking load off wheels is to stop a"flat" spot developing from sitting in one spot. If you are storing for a LONG period of time just hook the van up and go for a lap around the block and put it back.lot cheaper than buying something.
AnswerID: 197808
Follow Up By: Member - Maria P (SA) - Wednesday, Oct 04, 2006 at 18:02
Hi NRE,
The problem being is that the area to reverse the van in is also a tight fit, not much room to play with. We have to reverse the van to a certain point and then push it back. When this happens there is verylittle room on one side to get a jack to take to load off the wheels on that side.
Cheer,
Maria
FollowupID: 456385
Reply By: Truckster (Vic) - Wednesday, Oct 04, 2006 at 16:03
Lots of bricks, and a trolley jack?
AnswerID: 197810
Follow Up By: Member - Maria P (SA) - Wednesday, Oct 04, 2006 at 18:04
Hi Truckster,
Yeah sounds good but there is little room to move down one side of the van and you can not get the jack under that side unless you crawl under the van. What do you mean by a trolly jack?
Cheers, Maria
FollowupID: 456388
Follow Up By: Truckster (Vic) - Wednesday, Oct 04, 2006 at 18:10
Trolley Jack - google will find you a billion photos.
... So you crawl under the van.. jack it up, stack of bricks under it, lower jack, problem solved.
FollowupID: 456390
Follow Up By: Member - Maria P (SA) - Wednesday, Oct 04, 2006 at 18:23
Thanks for the tip, I shall research on the internet.
Cheers, Maria
FollowupID: 456393
Reply By: Member - Oldplodder (QLD) - Wednesday, Oct 04, 2006 at 16:20
Why not put the van jacks at each corner down? Will take a fair bit of load of the wheels?
AnswerID: 197813
Follow Up By: Member - Maria P (SA) - Wednesday, Oct 04, 2006 at 18:05
Hi Oldplodder,
Thanks for your reply, problem is that one side of the van there is little room and therefore you can not get down that side to put the jacks. Need something that you can slop under together and it raised all 4 wheels together.
Cheers, Maria
FollowupID: 456389
Reply By: dj Patrol - Wednesday, Oct 04, 2006 at 19:31
I also have that problem so when the van is in position I wind the front of the van down as far as possible on the jockey wheel then put the van stands at a piont behind the rear wheels and adjust them up to chassie then I wind the jockey wheel up as far as it will go and put front stands under and let it onto the jacks (not fully off the ground but far enough to take load off wheels and not causing flat spots takes about 5 minutes.
((ps its a 20ft van tandem axle ))
dj patrol
AnswerID: 197841
Follow Up By: Member - Maria P (SA) - Sunday, Oct 08, 2006 at 21:25
Hello dj Patrol,
Thanks for you response, it certainly has some merit what you have suggested.
Ta Maria
FollowupID: 456972
Reply By: Member - Doug T (W.A) - Wednesday, Oct 04, 2006 at 21:21
That so called flat spot you people are talking about will dissapear as soon as the tyre gets warmed up , but if you want to just take the weight of like i did with mine and I live in mine but i went to supercheap and got 2 pair of those little adjustable safety stands ,made in blo#dy China i might add and they cost $24.95 a pair. I placed them about half way from the wheels to the ends of the van and under the chassis , the wheels are still touching but I reackon half the weight is off and the van is stable.
AnswerID: 197862
Follow Up By: Member - Maria P (SA) - Sunday, Oct 08, 2006 at 21:26
Hi Dough T,
Thanks for responding, sounds like something to look into.
Cheers, Maria
FollowupID: 456973
Reply By: Steve - Wednesday, Oct 04, 2006 at 22:12
Providing that the tyres in question are not something out of the Ark...and that periods of time standing are months rather than years...and that they are in reasonably good condition ...do not even bother to address the 'problem' you think you have ...because you don't have a problem ..Why fix it when it ain't bust...Tyres will generally not suffer from standing fro long periods ...and as said before...in a couple of miles ..and a bit of flexing ..they will be perfect ..i.e. if they weren't before starting ...Put away the worry beads and well yes ...make sure they are inflated above normal before 'putting away '...usually they will drop a few pounds over time...Imagine that your ones are radials ...you could let us know the tyre specs if you still are not convinced you don't have a problem !!!
AnswerID: 197875
Follow Up By: Member - Maria P (SA) - Sunday, Oct 08, 2006 at 21:29
Hi Steve,
You probably are right, having little experience makes you get over cautious at that you do.
You probably are right why fix it if it ain't bust.
Cheers, Maria
FollowupID: 456975
Reply By: D-Jack - Thursday, Oct 05, 2006 at 00:42
You mean you would store the van for years at a time without it being moved? The answer to your question, go on more holidays:)
AnswerID: 197891
Follow Up By: Member - Maria P (SA) - Sunday, Oct 08, 2006 at 21:31
Hi D-Jack,
Yeah you are right go on more holidays, only problem we both are still working full time and have trouble getting away. Thought we would just test the waters by doing some trips (as works allows) away.
Thanks for replying.
Cheers, Maria
FollowupID: 456976
