For all 80 series owners (3FE type)
Submitted: Tuesday, Oct 10, 2006 at 15:04
Deano80series
All
I'm looking to do some work on my 80 series and was wondering if anyone has had any experience or encountered any troubles replacing the front disc rotors, the front hub seals and bearings and I was thinking of putting a new seal kit through the power steering pump as it leaks like a sieve.
Also if anyone could help me with some prices on what I should pay for this stuff that would be great
Thanks in advance
Deano
Reply By: ross - Tuesday, Oct 10, 2006 at 16:23
The disc are cheap if you buy after market ones,about $140 a pair+ another $50 for pads .
I think it will cost about $150 for the front seal kit + grease and diff oil.
Bearings are not usually replaced ,just repacked and adjusted.
Its an all day job. Ive never done an 80 but Ill suppose you need a 54mm hub socket
Power steering kit is about $50. You need to have it pressure tested otherwise the seal kit will be pointless.
198585
Reply By: Member - DOZER- Tuesday, Oct 10, 2006 at 16:53
Deano
Your 80 had smaller discs than later models....you have the option now of upgrading to better brakes, by buying the later model discs and a pair of later callipers...they are thicker and larger, and a good thing to consider at this point.
If you leave the back as is but do the work on the front, no other mods need doing like bigger rims...and it will result in better brakes. Everything bolts on.
Of course if you just want to replace, i would recommend DBA slotted rotors, which make a difference themselves, on either size....
The pump...i would buy a secondhander, as the bush could be worn, then nothing will stop the leak....all 3f's run thesame pump, and so do the cressida.
Andrew
ps
198590
Follow Up By: Deano72 - Tuesday, Oct 10, 2006 at 21:53
Dozer
Your all over it! Thanks for advice on bigger brakes. The anchor and I are planning a trip away and will be towing, so the bigger brakes seem like the way to go. But what size discs and calipers do I go up to?
Deano
457369
Follow Up By: Member - DOZER- Wednesday, Oct 11, 2006 at 09:43
Deano Give me a call on 0408965433 and we can discuss further. I think the later 80 had 12 inch discs, and 32mm thick, whereas the early 80 had 11 inch discs 27mm thick. When the 4.5 motor came out, they went bigger, but only changed the disc, backing plate and calliper lengths...so it all bolts up.
Andrew
Wollongong
457413
Follow Up By: Deano72 - Thursday, Oct 12, 2006 at 09:19
Andrew
Will give you a call tonight I'm on WA time
Deano
457579
Follow Up By: Member - DOZER- Monday, Oct 16, 2006 at 21:19
Deano
Sorry Mate, been
camping over the weekend, saw a few missed calls from 08 prefix....what i was going to tell you is that i have a set of larger brake callipersi from a later model front diff....if you wanted to go that way...could post.
Andrew
458324
Follow Up By: Deano72 - Monday, Oct 23, 2006 at 23:03
Dozer
Missed you a couple of times, decided to go with the same size disc but slotted variety ( thanks for the advice).
The local brake guru said that spending the money on bigger calipers and discs might disappoint due to the piston
bore not changing that much. It sort of made sense to me.
So now going with a set of DBA slotted rotors and I think lucas? pads on the front and once the back discs are up for renewal ( they are both just .2mm above the min thickness) I will change those over to slotted rotors also.
Once again thanks for your help
Deano
459696
Follow Up By: Member - DOZER- Tuesday, Oct 24, 2006 at 06:13
Sorry Deano
My phone is r/s at the moment... Later has larger swept area and thicker to discipate heat better, but what you have bought is not that far behind them...enjoy :)
Andrew
459712
Reply By: Member - Phantom (WA) - Tuesday, Oct 10, 2006 at 17:01
Hey there Deano,
I just looked up my invoice for you. I paid $220 for 2 front discs DBA Brand and $6.60 for front seals. Just paid $90.00 for front pads (non genuine). I work in a Dealership, so I think my pricing would be pretty good. Let me know if not and I'll cut his testicles off!! LOL
Steve
198593
Reply By: Barn - Tuesday, Oct 10, 2006 at 23:35
hi all,
l paid about $100 including freight for a seal kit (ebay) which included the bearings for the 80 series. l haven't yet fitted them as my mate rekons it can be a all day job. Hope l didnt get ripped of. They are non genuine
Barn
80series
198663
Follow Up By: Member - DOZER- Wednesday, Oct 11, 2006 at 09:38
Barn
Was this a swivel hub bearing kit, with axle seal, or a front wheel bearing kit ???
Andrew
457410
Follow Up By: Member - Phantom (WA) - Wednesday, Oct 11, 2006 at 12:27
Barn & Dozer,
It sounds like the swivel kit. I just had
mine done, parts cost $100. each and with a service and a transfer box repair (some git stripped my drain plug and split the the transfer box). Total cost was over $2000 (still recovering!). There was over 30 hours labour, luckily it was all at staff pricing.
Steve
457430
Follow Up By: barnster - Thursday, Oct 12, 2006 at 09:47
Hi Andrew,
it was a swivel hub set for bot sides. it included the bearings in the kit. they charged me $90.00 + $10.00 freight.
Barn
457580
