1kz Electronic Injector Pump
Submitted: Thursday, Oct 19, 2006 at 09:08
ThreadID: 38620 Views:1963 Replies:3 FollowUps:2
Hey all i was wondering if anyone knows of where i can get an injector pump for a 1kz it doesnt have to be brand new it just needs to work
Ian
Reply By: ross - Thursday, Oct 19, 2006 at 09:52
Whats happened to the old one,can it be fixed?
Its a Denso rotary pump and you dont need to go through Toyota to get parts for them
Good luck finding a used one ,they dont pop up often.
There is some difference between a 1KZ and a 1KZ TE so make sure you get it straight.
The 1KZ is a non turbo motor found in some Dynas
AnswerID: 199798
Follow Up By: Ta22Wepn - Thursday, Oct 19, 2006 at 16:58
thanks for that it is actually a 1kzte....
The electronics i it are stuffed as it had alot of algae pass through it
FollowupID: 458864
Reply By: ross - Thursday, Oct 19, 2006 at 19:46
Well I have a Denso 6 cyl rotary pump ,similar to yours,that is used on the 1HZ landcruiser diesel.
I had my spare pump dismantled,cleaned new seals,and bench tested for presssure and it cost $450.
It had been sitting for 4 years with diesel in it that had dried up.
I cant see how the algea would stuff up the electronics except maybe clog some sensors.
I also thought the electronics just sat on top and could be removed easliy
Used pumps can be a nightmare if they have very high klms and its impossibel to know unless a shop can test them.
AnswerID: 199890
Follow Up By: Ta22Wepn - Tuesday, Oct 24, 2006 at 09:06
where abouts did you get your one rebuilt? i have been sourcing out a few different places and most people want nearly $1000 to do it
FollowupID: 459737
Reply By: Ta22Wepn - Monday, Oct 30, 2006 at 11:13
could you possibly tell me where you got your one rebuilt?
AnswerID: 201776
