Saturday, Oct 21, 2006 at 15:41
Mickeyboy, I'm not claiming to be an expert. Just sharing my experience and
views.
While weight distribution within the vehicle and van and between them is important, it is generally easier on the vehicle to tow weight than to carry it. Tow capacity, ball weight and other practical considerations notwithstanding.
My Hilux has a load capacity of 915 KG and a tow capacity of 2250 KG, but not both. If I did both at the same time, I would exceed the Gross Combined Mass by about 450 KG. If I tow at the vehicle capacity, my vehicle load capacity reduces to about 500 KG; a big reduction.
None of this is as simple as it first seems. You need to get the full specs of potential vehicles. The key ones are kerb weight, GVM (the difference is the load capacity often including
fuel, passengers etc depending on how kerb weight has been defined), GCM (gross combined weight of the fully loaded vehicle and the fully loaded trailer), tow capacity and ball weight capacity.
To complicate things, you can often not rely on the tare weight and ball weight specified by caravan and CT manufacturers. You probably should check these at a weigh bridge.
All of this is why I try to maintain a reasonable margin of error. My Hilux, when fully loaded for a trip including boat, motor, trailer ball weight and all our stuff is right on it's 915 KG load capacity (might even be 50 KG over with extra beer and wine sometimes). But because the trailer is
well under tow capacity, my GCM remains within it's limit.
One of the reasons I got the ute is it's load capacity. Most wagons have much less load capacity, but the newer ones have a bigger towing capacity and GCM than my Hilux.
Many people just ignore all this stuff and travel way overloaded. If it is important to you (it is a safety as
well as legal issue), I can only suggest a nice big spread sheet of vehicle specs and load combinations. This will pop out a short list of vehicles for you to then target based on personal preference. But I would always maintain a margin for error. It is surprising what you (more likely your wife) wants to take on some trips.
I actually enjoy this sort of research when we are making decisions, but I'm probably a bit strange.
459252
