OT. Not 4wd related, but I would like your opinion anyway
Submitted: Monday, Oct 23, 2006 at 19:50
David from Engine Saver Low Water Alarms
My Daughters friend rang the other day for help as her car was making a "clicking" sound. Flat battery I said.
Off we went with the jumper leads only to find that the car, an XE falcon would start, but made a dreadful knocking noise.
Removed # 3 plug lead and the noise stopped. "PISTON" I expertly said, to much gloom. ( Owner is an 18 year old girl, just starting out in life )
Anyway I slowly drove it home to my place and said I would look at it over the weekend.
I slept on the problem and had second thoughts about the piston bit and removed the rocker cover to find # 3 inlet valve pushrod completely out of the rocker.
Scratched the old head a bit (
mine not the falcons) removed the rocker and pushrod to check for cracks and bends, all OK so refitted and runs good again.
Is this a common problem with old fords?
The valve doesn't seem to be sticky, the hydraulic lifter doesn't rattle and the car was recently serviced by a local mechanic and a ford motocraft oil filter fitted.
Can any one who has had this problem before and knows the answer please post a follow up as I want to be able to reassure the
young owner that this won't happen again but until I know what caused it I am in the dark myself.
David
Reply By: herkman - Monday, Oct 23, 2006 at 20:04
AH the little precious has had a failure.
I had a secetary that used to have the problem and it used to do it so often.
Eventually we bought a new push rod and the adjusting bolt, and the problem went away.
Have you checked that none of rods are bent, if they are chuck them away
Col
200548
Reply By: mr fixit - Monday, Oct 23, 2006 at 21:14
yep quite common. The valves stick in the head. Used to happen a lot in car yards after they had sat for some time. Everyone I have fixed had bent the pushrod. Roll in on the kitchen to see if it wobbles, I always used to replace the offending pushrods and most times I never seen the vehicle again.
Doug
200569
Follow Up By: mr fixit - Monday, Oct 23, 2006 at 21:17
That should read "roll it on the kitchin table" to see if its bent
Doug
459666
Reply By: frosty01 - Monday, Oct 23, 2006 at 21:19
Hi David,
Have had this happen on two different occasions with two different cars.
Both with alloy head cross flow engines. So this may
well be a ford thing.
200578
Reply By: David from Engine Saver Low Water Alarms - Tuesday, Oct 24, 2006 at 10:12
Thanks to everyone who replied to my question.
I think we will replace the pushrod as a precaution although the car is running OK at the moment.
Might try some upper cylinder lubricant as
well in case the valve was sticking.
David
200647
Follow Up By: Batman69 - Tuesday, Oct 24, 2006 at 10:30
While you replace all pushrods, take the time, spend a little extra and replace all hydraulic lifters as
well. Sounds to me like one of them is crook.
459758
Follow Up By: SA_Patrol - Wednesday, Oct 25, 2006 at 07:26
The early model XD,XE,and XF falcon had soft lifters. also the cam was a bit soft too.
had 2 bent push rods in my old XE many years ago.
459952
