Are we getting too complex?
Submitted: Tuesday, Oct 31, 2006 at 10:44
Member - Scott M (NSW)
I posted this as a follow up on another thread, however having just gone 11000 k's in 6 weeks in an old HJ47 (2H), I wonder if this may be
sign of the times. Oh and BTW, this is NOT an attempt by me to bash the later series, I'd probably have one if I could afford it, and to a fair degree they are more reliable.
It was interesting to see the number of people who came up to me at campsites etc. to look at the old girl and confess they cut their teeth 4wdriving on 40 series. To a man they all missed the robustness and simplicity of the 40 series. Didn't miss the rough ride and rattles tho! All of them had affection for the old 40's. Most said they used to do all their servicing themselves, however dropped this when they bought the later model.
Funnily enough and more significantly, it was a sentiment echo'd by a number of mechanics I spoke to. A few of them complained that it was just getting too hard (and costly) to keep up with the compliance with the later series Tojo's (and other marques), and were considering chucking it in as they were getting too complex. Allright if you are in a city dealership, but in a one man operation in the middle of woop woop, it was just too much hassle. Judging by the number of posts by fellow members who had to be towed out of the middle of nowhere at great $$$$ when a simple part broke, are the newer vehicles becoming less suited to Oz conditions?
Food for thought on the newer technology.
Reply By: Shaker - Tuesday, Oct 31, 2006 at 10:49
In answer to your question, YES!
202019
Follow Up By: Mike Harding - Tuesday, Oct 31, 2006 at 10:52
Make that a double.
461492
Follow Up By: Bonz (Vic) - Tuesday, Oct 31, 2006 at 19:02
yep what Mike said, sans goat
461598
Reply By: Member - Scott M (NSW) - Tuesday, Oct 31, 2006 at 11:14
One mechanic I spoke to (who will remain anonymous), said he was having to go down to
Adelaide for a week every 6 months to keep up certification on the 100 series. Major pain in the a*** for a one man operation. Said he wasn't even going to bother with it with the new 130's when they came out and was probably going to let the cert. for 100 series lapse. It would be less hassle to stick them on the back of a truck and send them south. He would be quite happy fixing up 40, 60, 70 and to a lesser extent 80 series. This was a
well appointed garage, and he wasn't old and stuck in his ways (late 20 or early 30's).
202020
Reply By: The Landy - Tuesday, Oct 31, 2006 at 11:35
I think you are right Scott, it is one of the reasons we went back to the 'old technology' - fully mechanical TDi Defender.
Good luck.
202021
Follow Up By: Member - Craig D (SA) - Tuesday, Oct 31, 2006 at 12:02
Same here....went from gu 3.0litre to the trusty gu 4.2tdi.
461503
Follow Up By: Michael ( Moss Vale NSW) - Tuesday, Oct 31, 2006 at 14:29
Yes the 4.2tdi!! But sadly it will be replaced by something no so reliable,, SOON!! Michael
461534
Follow Up By: Member - Duncs - Tuesday, Oct 31, 2006 at 17:29
Not in my garage it wont!!!
Duncs
461564
Reply By: TerraFirma - Tuesday, Oct 31, 2006 at 11:53
Scott, Very good point and a very valid one. I couldn't agree more. Compare a 2006 Range Rover vs your HJ47 being broken down in the middle of nowhere, an electrical fault being the suspect, you'd be up and running within a few hours and the Rangie would be on a tow truck en route to the nearest capital city dealership. The bells and whistles are nice sometimes however the simplicity of something like a FJ40, HJ47 and the others make it more fun. You have the real deals using Mineral Oils and the plastic fantastics using the Synthetics..! LOL
You can't hold back technology, but I'm all for slowing it down sometimes. By the way your HJ47 looks a treat, I'd be checking her out as
well.!
202026
Follow Up By: Member - Scott M (NSW) - Tuesday, Oct 31, 2006 at 12:45
Terra,
Thanks for the compliment.
Funnily enough, we did have an electrical problem on the Troopy. For reasons unknown, the wiring loom from the alternator to the battery dropped down onto the fan belts and chewed out just past
Kununurra (or that's where we spotted it due to the temp gauge going AWOL). I suspect the problem had started before the big K due to a
fuel warning light going on. We fixed the chewed wires on the side of the road with wire strippers and insulating tape, however when we got to
El Questro, I discovered that there was no charge going to the battery, and suspected this was probably a problem before I arrived in
Kununurra. The old girl was probably running with no charge for 5 days and kept on going. Turned out the charge problem was a 5 amp fuse in the regular box on the firewall (the only electronics in the beast!) - replace the fuse and she ran flawlessly for the rest of the trip. Struck 3 later series in garages with either a cooked battery or electronics.
461511
Reply By: Member - Oldplodder (QLD) - Tuesday, Oct 31, 2006 at 12:43
Good point Scott.
One reason I have not upgraded to a newer electonically controlled
fuel injected diesel, or to a 4wd with electronic ABS and MATT.
Like you, 2nd reason is the cost.
Makes you wonder how much a modern toyo/nissan/mitsu 4wd would cost with just the basics and the rest deleted?
Maybe why the Terracan and similar models a little cheaper, using slightly older technology by a couple of years.
Remember talking to Theo at
Birdsville. He was saying (If I remember correctly) that 50% of his recoveries from the Simpson used to be drive train related, diff, gearbox etc. Now it has changed to 50% being engine/auto box management systems breaking down. 4wds don't seem to go over dunes as
well on limp home mode :o). And you can not repair them in
the desert with basic tools. They have to be brought out and analysised.
Interesting that my wife did one of those market group surveys about 5 years ago. You know the type of thing, looking for women who drove 4wds less than 5 years old to get feed back on future marketing. Of 20 women there, there was her and our pajero, a couple of other similar cars like LCs and prados, and the RRs, mercs and X5s, and a few light 4wds. She was absolutely amazed that she was the only one that had been any where like
Birdsville, or the Cape, or
Lawn Hill, or one of a about 4 that even been to Fraser Is. , being Brisabne based. She was the only one that had done a 4wd driver course. Alot of the others were aghast that she would drive the car where it might get stone chipped or bulldust in it. The idea of having a proceedure for after hitting a roo really turned them off. (You know stop and check it is dead, if not use the axe to put it out of it's misery.)
202033
Follow Up By: Member - Scott M (NSW) - Tuesday, Oct 31, 2006 at 12:58
And that's the crux of my point I suppose, O-P. It's not so much that the users of the vehicle aren't capable of fixing problems, it's now getting to the point where certified mechanics in remote locations aren't able to fix these problems, as the cost of remaining certified/trained is too much.
Shipping to a major
population centre will be the solution in the near future I feel.
461516
Reply By: AdrianLR (VIC) - Tuesday, Oct 31, 2006 at 13:43
We had a GQ in the early 90's and it took us to lots of
places and even when 50L of seawater got spilt inside (another story!) all I did was pull out the seats and carpet and hose it out. As I have changed cars every couple of years (leases) I would occassionally think back to the "simple romance" of the GQ UNTIL I drove my brother-in-law's Maverick. How rattly, wallowy, noisy, rough, primitive etc it was compared to whatever I was driving at the time! However, the Mav was probably 15 years old, done the various desserts etc and still going without a problem. I would be reluctant to keep any modern car far beyond the warranty.
Just some rambly thoughts as I sit at my desk at lunchtime, in front of a computer, eating my sushi......
Adrian
202042
Reply By: Redback - Tuesday, Oct 31, 2006 at 14:06
The truth is your right, but as right as you may be it's the way of the future with all 4WDs and if the small one man mechanics of the bush don't keep up then the only place you will be able to get your 4B fixed will be in the closest big city, and that would be the biggest PITA ever, and the locals of these small towns will suffer most.
Not to mention the travellers that will be stranded because the local mechanic can't fix your 4b and not because he can't.
An excample was a vehicle that had a simple torn airbag in
Birdsville, car went into limp mode and had to be trucked to Mt Isa for repairs.
Now the vehicle could have been repaired buy the local mech but Toyota wouldn't let them.
Baz.
202045
Reply By: Member - Duncs - Tuesday, Oct 31, 2006 at 17:41
Of course your right Scott.
My first car was a 1975 Ford Escort, New Shape with the 1300 motor. I cut my teeth on that baby. Learnt all about mainenance, and mechanical repairs. I remember standing in a phone box on Elizabeth Drv Liverpool and getting advice from my dad on how to fic the carbie that was laid out on the shelf in the phone box. Now I'm not doing that with the diesel pump from the GU.
I actually considered buying one a few months back, 18yr old daughter needing a car seemed like a good excuse to indulge my sentimental love for these old cars.
Then I looked at one............................ and drove it........................we baught a 93 Camry for $3000 with 12 mnths rego.
While the 93 Camry isn't exactly cutting edge technology these days it was a long way better than 1975 and serves to make my point. My first 4wd was a 1980 MQ it was a good solid old girl but having lived with a GQ I wouldn't go back. A few months ago I had a ride in a GQ, again a good solid reliable old truck, comfortable too compared to the GQ but when I compare it to the GU it is really a lot more like a truck. The GU is heaps more comfortable and while it is no faster it is quicker from point to point because of that
Duncs
202092
Reply By: Davo_60 - Tuesday, Oct 31, 2006 at 17:42
Emissions and evironmental considerations aside, yes vehicles are becoming unservicable beyond warranty. We have a diesel VW Golf which is a fantastic vehicle, but wouldn't keep it for 5mins past warranty. I can imagine what one of those injector pumps on every cylinder is worth. Also have a 60 Series diesel that we will keep for as long as possible, and if they were making new ones I would line up to buy. Rattles, a bit of dust and noise don't worry me, just reliability, capability and something I have a chance of repairing myself.
202093
Reply By: Peter 2 - Tuesday, Oct 31, 2006 at 18:00
Totally agree, after having had Landcruisers (7 in all) for over 25years and being very disollusioned by the ever decreasing quality and lack of serviceability of the later models that is why I have an 18 year old Humvee, simple to fix, very reliable, indestructable and rides much better than most 'modern' 4wd's besides being much more capable and practical in the bush. Parts are cheap and freely available.
Another point to remember is that older vehicles are much friendlier to the environment when you consider the "cradle to the grave" scenario. Especially when the "service life" in the Humvee's case is 25 years.
I can't imagine too many of the current crop of 4wd's being an economical propostion in 10 years let alone 25.
The manufacturers want us to keep buying them so they are usually made to last the length of the warranty.
The day might come when someone uses consumer laws to take the manufacturers to task as the goods being sold are not 'fit for the purpose'.
I agree with Scott too the HJ47 we had was the best troopy of the four we had.
202100
Reply By: _gmd_pps - Tuesday, Oct 31, 2006 at 18:30
well,
well,
well are you getting too old ?
I have reapaired a 1966 VW Bus (changed clutch and took an engine apart) in -20 degree frost in the middle of nowhere (in 1977) and and other stories .. then I have been driving a 525BMW and a 380SE Merc various models full of electronics and never really had a problem ... one of my current vehicles is a 280SE Merc (year 84) already full of electronics and hydraulics (central locking, climate control etc). You are talking stone age with the engines you mention .. just as many people can not put up a website and IT people in a small town can not do a Macromedia Flash presentation does not mean it does not have its uses .. in many fields people have to educated themselves to follow times .. give an ipod to you 90 year old grandma .. does she know what to do with it ? .. many people are used to do basic work on a car .. right .. Do you do your house electrics ? here in Australia you need to be licensed .. what a cr@p .. where I come from you just do when you think you can do it .. only for certain situations you need a licensed person to do the certifying but not necessarily the work .. its all what you are used to and what you are willing to put in .. an OBDII tool nowadays is less than $500 for a laptop and you can see everything your engine does ...
the local mechanic can not fix a problem because he does not have the service equipment .. so what .. big deal .. with the new computer stuff you can diagnose much better .. monitor things closer before they break .. electronic failure is not a serious as one may think .. every system has a limp mode and mostly its diagnostics ... when an injector goes bad .. ok so you drive with one less until you can get one delivered ... This is not just to have an opposite position .. I conciously made that decision when I purchased my new truck .. no warranty, no service from a manufacturer here in Australia .. so what .. pick a model which is reasonably tested (not first generation), wait until almost the end of the production cycle (then you know most problems and recalls) and then order it new (so you know what was done and who has driven it).. get all the diagnostics for your vehicle, learn how to use them and you should be right ..
well I will see if I will be right :)))) ...
don't get me wrong.. I am not saying old technology is rubbish .. it's ok for some who do not want to learn and prepare and are willing to make the compromise (if there is one) ... less complex is often better .. but then again you are missing on certain things ..
how about an old PS2 with floppy drives (no hard drive) for editing 100MB image files ... simply not possible because you need 100+ floppies to store one image .. so you just can't ... you make choises and you make compromises ... I do not trust auto mechanics unless I have seen the diagnostics myself ... and there is nothing on my truck I would not be able to fix myself ... just a matter of how much time I spend learning my diagnostics ... you get all manufacturers handbooks for your vehicles so what has the little village mechanic you
don't have ?
well maybe a decent lift when you need to get under the car ...
there are other examples ... e.g. you see so many people having trouble with broken frames or trailer axles .. etc etc needing a weld ... seen abandoned trailers because people did not want to spend the money on recovery or towing. Nowadays there are many ways of having portable equipment for welding. There are electronic welders weighing hardly 3Kg and not much larger than my wifes cosmetic case ... I make her leave the case at home and I take the welder instead.. ok I also have a generator and some of those welders don't like generators that much but you get combos to work .. I have a boat trailer and when I go anywhere with it for a long time I expect trouble .. sure you will get in trouble at some point .. so .. I carry a welder, and a small angle grinder and some steel bits and pieces..
and no ... I don't mind to spend an extra night to help others who don't ...
It's all about being prepared and when the vehicle becomes more complex you have to prepare better .. thats all .. in 20 or 30 years those simple engines will be gone .. and todays ones will be simple .. all a matter of perspective and age ????
have fun
gmd
202110
Follow Up By: Member - Scott M (NSW) - Tuesday, Oct 31, 2006 at 19:58
gmd,
I don't necessarily disagree with you, however the point the mechanic was making was that it now takes a lot of effort & $$ to remain an authorised service mechanic for the large distributors. Given the current litigous nature of the public and nervousness of the the suppliers, no-one is going to service a vehicle while under warranty unless authorised. In the older days, this was less of an issue, however given the complexity of current vehicles, one wonders whether the true market is the genuine off road users, or the city market.
Diagnostics are getting easier (if you have the equipment) ands I agree there is no substitute for preparation, however the old mantra of 'the more bits there are, the more likely they are to break' combined with the instantly fatal nature (to the vehicle) of these bits is making the servicing of the later vehicles more of a specialist art.
my 2c worth.
461611
Follow Up By: _gmd_pps - Tuesday, Oct 31, 2006 at 20:51
agree with you Scott.. I feel for the mechanics being bullied by the manufacturers .. a friend of
mine has a workshop .. know a bit from him .. but on the other side the public does not deserve better ... The manufacturer warranty turned a bit into a life insurance rather than help for the odd occasion ... hard to break the cycle ...
I have never used "authorised" workshops for my service even on new cars. A couple of times I had a warranty claim and it was honoured despite me not having a service history in the service book ... There is a good thing here in Australia and that is that you can take someone to court with very little money ... you don't need a lawyer .. you can do it yourself ... the dealer usually will take a lawyer and has to pay for it ... so .. usually they rather fix a problem under warranty than to be taken for a lawyer ride ...
The public has the power .. always ... it's just not used right ... electing the wrong people that is and making bad choices like feeding fast food to the kids ...
have fun
gmd
461630
Follow Up By: Scooter13 - Thursday, Nov 02, 2006 at 23:25
maybe that's it gmd. Given the extent of Manufacturers Warranties these days, I suspect the vehicles are more being designed to last the Warranty period, rather than a lifetime.
In past times, vehicles like the Land Rover and Land Cruiser were sold on the reputation they would 'last you a lifetime'. Nowadays, they don't give a FF past the warranty period, and it's probably not in their best interest if they last forever....
462258
Reply By: Member - Oldplodder (QLD) - Tuesday, Oct 31, 2006 at 19:05
Just as another comment.
Renault are developing the throw away engine.
Good for 100,000k, it auto tunes and does everything else it needs too for 100,000k.
One little problem is the oil. They are waiting for the right oil that will last 100,000k, so it never needs changing. Just change the engine every 100,000k. Cheaper to service that way.
I know, the japanese already have 50,000k engines. :o)
202123
Follow Up By: Muddy doe (SA) - Thursday, Nov 02, 2006 at 23:50
In Formula 1 they have 1,000km engines! The engines are designed to last for 3 races before being replaced. Mind you they are being wrung out to 19,000 rpm and provide maximum power during their short lives.
Even worse are the engines in top
fuel dragsters that are virtually rebuilt after every run or every meet. The lifespan of the engine is measured in minutes!!
Point is that every engine has a design life - be it measured in hours or in hundreds of thousands of km.
All a matter of economics.
Muddy
462271
