info on pearce-simpson UHF RADIO
Submitted: Monday, Dec 11, 2000 at 01:00
David
I am trying to find out any info on a pearce-simpson
UHF radio model: UF 2020, in particular, how to turn of the squelch as it is controlled by buttons instead of knobs ( i havent got a manual for it). Any info would be greatlt appreciated, cheers, David.
Reply By: Darryn- Friday, Dec 22, 2000 at 01:00
David you could try a Uniden dealer as I think your radio is a Uniden radio with Pearce Simpson branded on it. Also what is the problem with the squelch as most Uhf/Fm radios the squelch is either on or off despite many Uhf CBs having rotary controls? This means that once you remove the hissing/rushing noise you are not doing much more. Also if your set has inbuilt selcall facilities you may have enabled the Quiet mode which means you wont hear anything until someone sends your selcall code from another radio.
Hope this might help,
regards
Darryn
93
