ARB tyre deflators - verdict?
Submitted: Tuesday, Oct 31, 2006 at 21:38
ThreadID: 39021 Views:10121 Replies:9 FollowUps:7
So have any early adopters who have given the ARB tyre deflators a good workout got any feedback? It's a single device that removes the inner stem from the valve with a gauge attached - totally different design to Stauns.
Was looking at them at the 4WD show in Melb - they sold out on the Saturday pretty much while I was looking at the last one.
Just wondering about the ease of use and accuracy - looks simple enough.
Reply By: gupatrol666 - Tuesday, Oct 31, 2006 at 21:55
I have one and love it. Very easy to use, way faster and more versatile than Stauns.
AnswerID: 202177
Follow Up By: Teabag - Wednesday, Nov 01, 2006 at 08:41
gupatrol666,
I beg to differ on faster than Stauns. A mate has one and he took heaps longer to let all 4 tyres down the my Staun. This is many due to the fact that you can do all 4 tyres at once with Staun. If it was a one tyre race then the ARB deplator would be quicker....
FollowupID: 461711
Reply By: Bonz (Vic) - Tuesday, Oct 31, 2006 at 22:03
I had a look too and they seemed fiddly
AnswerID: 202181
Reply By: Markymark - Tuesday, Oct 31, 2006 at 22:21
I experimented with an idea a few weeks ago which worked, is simple and cheap. I got out the tyre inflation attachment device that you use to pump up tyres with a 240v compressor (already have a gauge fitted) and it gives you an instant presurre reading and all you need to do is push the trigger to let the air out and release when it drops to the desired pressure. The air flows out the open end that would normally be attached to the compressor hose and done!
Till then I had been using a sturdy little gauge where I had to take a reading, take it off and let some air out, put it on again for another reading and so on. Not any more. I think I paid around $20 for the thing and it reads 2psi over my little gauge.
Anyone else done this?
Mark.
AnswerID: 202188
Reply By: David from David and Justine Olsen's 4WD Tag-Along - Tuesday, Oct 31, 2006 at 23:24
The ARB unit removes the valve so deflation is rapid. More versatile than the Stauns but a bit more fiddly. I currently have multiple sets of Stauns for various pressures so it would be better for that.
AnswerID: 202200
Reply By: Rock Crawler - Tuesday, Oct 31, 2006 at 23:57
the staunts are fiddly to set up , but once its done , its great. screw them on and wait . I usually set them to 20 psi as it give my 315 plenty of footprint
AnswerID: 202204
Follow Up By: Muzzgit [WA] - Wednesday, Nov 01, 2006 at 00:13
Stauns aren't fiddly to set after you have done it once. I have 3 set at 18, which is how they come, and one set at 12 for heavy sand. The one at 12 is marked with nail polish. oooohh, hmm, betty!
I can't beleive I used to do it the old way as described above. I also can't beleive my brother is pig headed about them and squats down, one wheel at a time with a stick or twig to let his tyres down!
FollowupID: 461687
Follow Up By: Member - Tonester (VIC) - Wednesday, Nov 01, 2006 at 10:17
Oi! There's an art to finding the right stick to do it with! Too thin it breaks. Too fat it don't fit or won't depress the valve enough.
FollowupID: 461731
Follow Up By: Pajman Pete (SA) - Wednesday, Nov 01, 2006 at 13:02
I've got 2 set at 22 for dirt and 2 at 16 for sand. If I'm airing down on sand I put all 4 on, 16's on the front. Then dropping the back tyres to 16 is quick, just swap the 16's to the back to let out the last 6 psi.
Pete
FollowupID: 461748
Follow Up By: Blaze - Wednesday, Nov 01, 2006 at 13:29
Anyone have trouble with their Stauns, I have 2 set for 20psi and the other 2 for 15psi for sand. Seems every time I use them they are different. I used the 15's the last time I was in some heavy sand and when i checked the tyres after deflation, all had diferent psi, lowest was 10 and highest was 17. They are kept clean and in there case.
FollowupID: 461754
Follow Up By: Pajman Pete (SA) - Wednesday, Nov 01, 2006 at 13:52
No problem with mine, I still don't trust them and always check before driving off. Here they all are at a checked 16:
!MPG:8!
Pete
FollowupID: 461760
Follow Up By: Shaker - Thursday, Nov 02, 2006 at 09:37
I wouldn't trust them either, every time I set them off a set pressure tyre, they are different.
FollowupID: 462002
Reply By: cowpat - Wednesday, Nov 01, 2006 at 00:10
The ARB deflator looks suspiciously like another. Have a look here for a comparison of 10 different deflators: Site Link
My only worry would be that the rubber seal on the core is probably not designed for frequent insertion/removal, but of course you've got spare cores in your spare tyres/tubes if need be. Casper
AnswerID: 202207
Reply By: Member - Phil G (SA) - Wednesday, Nov 01, 2006 at 16:12
I bought the ARB one recently. Never went for the Stauns because I like to use different pressures for different conditions. Checked the gauge and it seems accurate compared with two digital ones. Its a nifty gadget, which is why I bought it!!
AnswerID: 202301
Reply By: Truckster (Vic) - Wednesday, Nov 01, 2006 at 23:49
lmao, why bother...
Valve core remover on an old valve stem $0.00 from B/stone and away you go...
the price they charge for things to let air out is criminal!
whats the old saying about a fool and his money?
AnswerID: 202418
Reply By: Member - BBB - Thursday, Nov 02, 2006 at 06:43
Is the ARB one the same as the Bush Ranger that I have got Anaconda had them for $19.95 and the good.
AnswerID: 202437
