generators and air conditioners
Submitted: Wednesday, Nov 01, 2006 at 20:57
inspired
Hi all,
Done some research on the virtues of the Honda eu2000 and eu3000 generators and equivalent Kipors with respect to running air conditioners.
But I am not clear on whether the Honda eu2000, once having started the a/c on full throttle, can then be switched to eco-throttle. Is it a case of whatever setting the generator starts the load on, it must stay on that?
That being the case, would a 3000 watt generator run the a/c more efficiently, more quietly and more effoftlessly than a 2000watt?
My inclination would be to buy a Kipor 3000 if that were the case
-Inspired
Reply By: Motherhen - Wednesday, Nov 01, 2006 at 21:04
Stick with the Honda - it does the job, is quiet, compact and lightweight. Good reputation too. Can't remember about the throttle, we didn't need the air con this year.
202368
Reply By: Member - BBB - Wednesday, Nov 01, 2006 at 21:31
I have the honda it will run the air con easerly but I have not had it on eco as I think the load is to great let me know if you find out diferrant imfo about the use of the ECO
BBB
202379
Reply By: Tony Shaw - Wednesday, Nov 01, 2006 at 22:42
Hi there Inspired,
about 12 months ago i sold a kipor kge2000ti to a guy to run his split system in his van. When he tried it, it would start the aircon but when the aircon went to cycle (ie start up again after stopping it's compressor) it wouldn't kick back in. We then tried the 3000 and it did the exact same thing. I have no idea why though.
About 2 weeks later he rang me and told me that he had contacted a honda dealer who had bought out a eu2000 and that had run the aircon no worries at all including being on eco throttle. This being 2nd hand information i'd check with a honda specialist before purchase.
I'd recomend the Honda.
Cheers, ToNy!
202400
Reply By: Member - andrew B (Kununurra) - Wednesday, Nov 01, 2006 at 23:22
Gday Inspired
SomethingI haven't read on this
forum, but a friend had a motorhome with 2 split systems which ran on the eu3000 Honda on eco throttle, and the rep said he'd have no trouble with a 2000.......as long as he didn't fire both of them up at the exact same time. The trick was he had inverter air cons, so the compressor had a soft start up, and didn't stop and start but slowed down or sped up depending on their workload. Maybe something to keep in mind for new air con purchases, but expensive to replace the existing unit. He also sourced an auto starter for the eu3000 for a coupe of hundred bucks, so he could remote start and stop the gennie from inside the bus.
Hope this may be of help....to someone
Cheers Andrew
202407
Follow Up By: Member No 1- Thursday, Nov 02, 2006 at 08:14
best to have soft start for aircons....the compresser (non soft start systems) can pull around 7 times full load running current on start up.....ie lots of amps
461971
Reply By: pt_nomad - Wednesday, Nov 01, 2006 at 23:46
seems global warming is topic at the moment.
generators chite me, make it a honda and do you neighbours a favour.
Make an open door and do the globe a favour.
202415
Follow Up By: inspired - Thursday, Nov 02, 2006 at 01:44
Pt_Normal.....An open door lets in the 40 degree heat into your 38 degree van. Not much sense in that.
461944
Reply By: Dave ....Adelaide - Thursday, Nov 02, 2006 at 00:17
Hi Inspired
I have the Honda EU 2000i and run the aircon in our van on the eco setting all time no probs ...even microwave will run on the eco setting ....Cheers ......Dave
202420
Reply By: GaryInOz (Vic) - Thursday, Nov 02, 2006 at 06:04
I use windows...........
202434
Reply By: Member - Reiner G (QLD) 4124 - Thursday, Nov 02, 2006 at 06:47
If I needed all that to enjoy the great outdoors I would stay home and watch Outdoor Videos..........safes carrying all that stuff around and safe petrol.
Anybody still does
camping with gas lights and ice blocks in the?
Reiner
202438
Follow Up By: Kumunara (NT) - Thursday, Nov 02, 2006 at 08:17
I agree with you Reiner.
My trouble and strife does not. She likes a few comforts. My quality of life improves if I keep her happy.
461975
