80 series front diff?
Submitted: Thursday, Nov 02, 2006 at 15:07
nigilor6
Hi there everyone i have a question for cruiser owners and mechanics if u are about, long story short there is a series of clunks coming from car and originally thought it was front diff, this is not the case now i am trying too put left hand side shaft back in but is out by about ten mill and will not line up with diff, is there a special trick too this or is there meant to be something else inside the axel housing that helps line up shaft and diff? all thougths and ideas will be appricated in this episode of back yard mechanic and lessons in colourful language
Reply By: Member - Jiarna (NT) - Thursday, Nov 02, 2006 at 15:12
I recently changed the CV joints on my 80 series. The axles came straight out, and went straight back in, as far as I remember. I think if it's not going in properly, try rotating a spline at a time until it does. Can't think of anything else to try.
Good luck
202560
Reply By: Ray Bates - Thursday, Nov 02, 2006 at 15:48
While we are on the subject of 80 series diffs are the front and rear interchangable?
202566
Follow Up By: HJ60-2H - Thursday, Nov 02, 2006 at 15:55
no
462104
Follow Up By: Of Mice & Men - Thursday, Nov 02, 2006 at 16:50
As HJ60 said, No. Climb under your car & have a look at the difference in size. Rears are much bigger then the front.
OM&M.
462120
Follow Up By: Member - Karl - Friday, Nov 03, 2006 at 11:03
Front diffs are same as the Hilux.
Karl
462353
Reply By: HJ60-2H - Thursday, Nov 02, 2006 at 15:58
grab the end of the axle and then push DOWN on the CV part. This will move the spline inside the diff up so it should line up. Push whilst you are doing this and it should slip in.
If this doesn't work first time then try again etc etc etc etc
202571
Reply By: nigilor6 - Thursday, Nov 02, 2006 at 17:30
Well thanks for your info people, i had tried all ways all after noon but the thing just wouldnt go in, instead i undid the bolt on top of the axil that holds a bracket for the brake lines cleaned up a bit of welding rod bent it to a hook and hooked the axel and lifted it up and walla 10 seconds later it is in so there it is thankyou again for your ideas as i had been trying them all friggin afternoon
oh
well
202596
Reply By: nowimnumberone - Thursday, Nov 02, 2006 at 19:40
just hope with all the banging around trying to get it to fit that you havnt damaget the new axle seals you fitted.
202644
Follow Up By: Member - John - Thursday, Nov 02, 2006 at 22:44
new seals, what new seals??????????
462243
Reply By: Member - DOZER- Thursday, Nov 02, 2006 at 22:13
Hope im not too late...lol....but it sounds likr the c/v is worn....around corners they go click, click, click, click. A simple way to get a longer run is to swap left for right.
Andrew
202701
Reply By: nigilor6 - Friday, Nov 03, 2006 at 11:58
Nah i did a practise run to see how easy it would be to put in before i fited new seals and the cv's arent worn
202796
