Centre Pole Tents In Wind
Submitted: Sunday, Nov 05, 2006 at 19:37
garbage
I've got a centre pole tent and have found that with the tent rocking around in the wind, the extendable centre pole tends to shorten. Does anyone else have this problem?
garbage
Reply By: Emo - Sunday, Nov 05, 2006 at 20:14
My centre pole tent has a built in shock absorber for windy weather. The wife and I got caught in a heck of a stormin
Geraldton years ago and it was fine.
203228
Reply By: Member - Vincent A M (NSW) - Sunday, Nov 05, 2006 at 20:28
I've had two centre poles & both have been fine & great tents, & have been through some great storms without a problem. However the new one had a PVC fitting with wing nut that would not hold tension on the centre pole went back to a steel nut with tension bolt & have had no problems.
203234
Reply By: GaryInOz (Vic) - Sunday, Nov 05, 2006 at 20:28
it's called cold weather and old age (wink, wink...)
Or Willems "rope".
203235
Reply By: cackles - Sunday, Nov 05, 2006 at 20:38
it could be worse, I once helped a friend chase her dome tent down the track.
cackles
203237
Follow Up By: GaryInOz (Vic) - Sunday, Nov 05, 2006 at 20:42
One reason I don't really like dome tents is they have a tendency to go teardrop shaped in a 40 knot gale. Makes for a rather uncomfortable night....
462811
Follow Up By: Member - Robyn J (QLD) - Sunday, Nov 05, 2006 at 21:04
The newer ones with the extra poles dont move at all in the wind. Our first dome tent, I can remember at Seisa in 1990 lying in the tent and the poles coming down to meet me but our newest one which we take when we dont take the camper trailer does not move and we have had it is some strong winds on
the beach.
462823
Follow Up By: mfewster - Monday, Nov 06, 2006 at 07:08
Domes with alloy poles rather than fibreglass seem to hold their shape better. Centre pole tents can lose a lot of floor space in high winds and wet weather as the walls billow inwards. Some brands are really bad, I've seen some lose
well over a foot of useful floor space on the side the wind is coming from.
462868
Follow Up By: Pajman Pete (SA) - Monday, Nov 06, 2006 at 13:47
We have a geodesic dome (4 poles over the dome) that is just fine in a storm. Our older dome was useless and used to collapse inwards in a strong breeze.
462915
Follow Up By: cackles - Monday, Nov 06, 2006 at 17:21
you "domies" are a loyal breed aren't you?
I got put off the domes because putting the poles together was too stressful. Once your at the end of the pole the begining starts to fall apart, so then you go back to the begining and put that together while the end falls apart and so
forth and so on.
The boys loved watching my comedy routine and paying me out about getting a job on the BBC
cackles
462950
Follow Up By: Richard W (NSW) - Monday, Nov 06, 2006 at 17:42
Sure are.
Theres an art to it.
Ive got a sprung steel pole Serrengetti canvas tent which I can put up by myself.
Worst storm I had was 100kph wind with hail. Needed the guy ropes to hold it down.
462952
Follow Up By: Brew69(SA) - Wednesday, Nov 08, 2006 at 17:36
I am amazed at what a geodesic dome tent copes with.
463385
Reply By: CLC50 - Monday, Nov 06, 2006 at 07:21
Hi all
Have a 6m x 4m PVC tarp heavy duty with 20 perimeter poles & 2 centre poles with a tire down flap on centre poles to fit rope to ground peg supports all with plastic base plates, have no problem on beach camps ,I use the yellow plastic sand pegs.
Note ( I also clip tarp to rear of truck )
203284
Reply By: Member -Signman - Monday, Nov 06, 2006 at 08:39
We have an older centre pole 'touring' tent. Had some s/steel rings sewn in at each corner at the top of the sides. If big winds around- we use guy ropes down to the corner pegs. Stops the rocking and movement. OK in the Tassie westerlies.
203294
Reply By: rolande- Monday, Nov 06, 2006 at 12:40
G'Day,
Most touring type tents these days come with a side pole option. I have used both and find the side pole much better for both high winds and for keeping floor space. Check the size of your tent, you may find a side pole kit available to suit
Rolande
203314
Follow Up By: cackles - Monday, Nov 06, 2006 at 17:15
the kit costs about $35 so not an expensive option.
cackles
462949
Reply By: Member - Chris R (NSW) - Monday, Nov 06, 2006 at 14:33
Yep had your probem and have occasionally used a second pole alongside first. I have rings sewn into top external corners but rarely use them. The tent came with the spring loaded type centre pole but it did not allow the tent to be fully raised and allowed too much sag. Two poles sounds odd but it works really
well and allows quick 'middle of the night' first response to storm.
Chris
203326
Reply By: garbage - Monday, Nov 06, 2006 at 15:53
Thanks for all the replies! I switched the centre pole with another pole I had on hand and the pole didn't slip much / lose its height. I also do have the side-pole kit, so will try that as
Regards,
garbage
203340
Reply By: smort - Tuesday, Nov 07, 2006 at 06:32
Hi garbage
centre pole tents usually siffer from another problem - the pole comes out of the hole in the centre and make another in the roof - dont know if it has happend to you.
Solution - half a tennis ball with a hole in it for the pole and a split pin through a hole in the pole tip to stop it coming off. Also helps to stop the rain coming down the centre pole.
Another problem is the spring loded and rigid poles either dont put enough tension on the roof and walls or they slip overnight.
Solution - drill a hole through the centre pole in a couple of
places (different tension) and put a split pin or a nail through the inner and outer - halves dont slide any more.
As others have suggested tethers on the roof rim can be an asset as
well - without it they fly pretty
Hope this helps
smort
203473
Reply By: SKI'er - Wednesday, Nov 08, 2006 at 16:56
Short answer "Yes" we had/have the same problem with our 20 odd year old Boots Great Outdoors centre post "witch hat " tent. Easy to fix.... There are 2 parts to the pole one bigger, one lesser in diametre. Set the tent up in your garden and mark a spot on the less er diameter section where the bigger diametre slides across when locked.
Take the post out and the sections apart and drill a 2mm hole through both walls of the lesser diametre one.. Reassemble the post and extent until the holes are just visible and slide a long shanked pop rivet or a nailthrough both holes. PS add extra holes 25mm above or below to allow for times when the tent is wet and doesn't seem to want to go up as far as when it was dry.
Our locking mechanism went togod after about 10 years and the nail has worked ever since. How we rejoice that our "old witches hat" dances all night in a wind with never any damage whilst the new light weight fabric tents fare less
SKI'er
203736
Follow Up By: garbage - Wednesday, Nov 08, 2006 at 18:58
Hi SKI'er, thanks for that really good suggestion! I'll give it a go.
garbage.
463410
