stromberg carby
Submitted: Monday, Nov 06, 2006 at 15:46
ThreadID: 39190 Views:2632 Replies:6 FollowUps:3
hello,
I have a stromberg carby fitted to my old landrover. I had a problem on the weekend that when i started the car fuel started bleep out all over the place. So I took the carby off and checked all the needle valves were clear and not clogged open, and I checked the ploat wasn't stuck. When i restarted it again... same problem. I seems to be leaking through the bottom, under the float chamber??? Anyone had this problem before?? I think the carby is off a red motor? I have had this carby for 4 or 5 years with no problem on my four cylinder landy/
thanks
timbo - darwin
Reply By: Wayne (NSW) - Monday, Nov 06, 2006 at 15:54
Timbo,
It would have to be a gasket.
The good thing about the Stromberg carby is that there are only two moving parts and they are interchangeable.
Wayne
AnswerID: 203341
Follow Up By: N.T. Home - Monday, Nov 06, 2006 at 15:57
Only one gasket that i can see, that is between the top and botom halfs of the body, no leaking there. The leaking I have is coming from the linkage which is directly under the float chamber???
FollowupID: 462937
Reply By: howesy - Monday, Nov 06, 2006 at 16:34
If it is coming from the linkage the bush that the shaft goes through is stuffed and its uneconomical to get rebushed when $10 at the wrecker will buy a stromberg and put a kit through it.
AnswerID: 203349
Reply By: Member -Signman - Monday, Nov 06, 2006 at 16:44
So the float is working ok- but the needle & seat (thats the bigger thing runs off the float) could be staying open. Remove the needle & its seat and see if its closing properly - and no crap where it seats...
AnswerID: 203350
Reply By: Nav 8 - Monday, Nov 06, 2006 at 16:46
Take the top of the carby off, you can do this without removing the complete carby. Check the fuel level in the float bowl, it should be about a little over half full. If it is full the needle and seat are leaking. If that is ok,or before you do anything check the two plugs under the bottom of the fuel bowl to make sure they are not leaking, They give access to the jets you can remove the plugs and check if the jets are tight. they somtimes can come loose. With the top off the carby check the power valve for tight, it is below the plunger and spring,have seen them come loose before. Check that out and see how you go,Regards Nav.
AnswerID: 203351
Follow Up By: N.T. Home - Monday, Nov 06, 2006 at 16:53
you blokes are f**king great, thanks very much, will try thoughs things when i get home tonight.
timbo
FollowupID: 462948
Reply By: Member - Alastair D (NSW) - Monday, Nov 06, 2006 at 16:59
All suggestions as above but in addition I have a memory of a Stromberg with a hollow brass float which had a pin-hole corrosion point. The float partially filled and hence the same symptoms. May be thinking of a different type.
good luck
alastair
AnswerID: 203353
Follow Up By: Nav 8 - Monday, Nov 06, 2006 at 17:57
Yep,your right I have seen that as well and it was a Stromberg...Nav.
FollowupID: 462955
Reply By: Member - angus K (QLD) - Monday, Nov 06, 2006 at 21:35
Also check the lead plugs in the main body . These can come loose over time and weep fuel .Sometimes a simple tap with a hammer will reseal the plugs .The plugs are put in to seal the fuel passages after drilling when the carby was made.
Cheers Angus
AnswerID: 203415
