BFGs tyre pressure what?
Submitted: Monday, Nov 06, 2006 at 22:21
ThreadID: 39208 Views:2975 Replies:7 FollowUps:2
Hi All
What tyre pressure are you all running?
I have a GQ wagon With BFG ATs KO 33X 12.5 .Im heading down south on the black stuff and proably only carring 2-300 kgs extra including us.So what are your pressures?Im running 40 psi around town.Does this sound right?
Cheers Niffty
Perth
Reply By: Scubaroo - Monday, Nov 06, 2006 at 22:37
I run 36psi around town as I felt the higher pressures harshened the ride (about to get HD springs fitted so now it's moot!). No noticeable tyre wear other than normal.
Thinking of trying higher again though as quite a few people seem to run >38.
AnswerID: 203441
Reply By: Off-track - Monday, Nov 06, 2006 at 22:42
42psi on mine for blacktop has been the best for wear and control.
AnswerID: 203444
Follow Up By: Member - BUNDY BOY (WA) - Tuesday, Nov 07, 2006 at 00:13
hay Niffty
i run 36--38 in the front 40 rear..when round town ..on trip loaded...40front ...42--44 rear depending on weight ....
Darren
FollowupID: 463038
Reply By: Member - Teabag (NSW) - Tuesday, Nov 07, 2006 at 07:48
Mate, I run 42psi Front and 44psi Rear on the Black top. Running these pressures does provide a harsher ride though I have experience far better tyre wear and a generally prefer a firmer ride anyway. The tyres seem to wear a little more even.......I have had 4 sets of BFG's and every set has achieved 80000km plus.....
AnswerID: 203478
Follow Up By: cokeaddict - Tuesday, Nov 07, 2006 at 13:00
Yeh same here...42 front - 44 back. Works well.
Ange
FollowupID: 463090
Reply By: Darian (SA) - Tuesday, Nov 07, 2006 at 13:45
Yep - ditto - run mine high on the blacktop to improve life (F 36 R 40) - on my second set now - back down to around 30 at most for any stony roads, with reduced speeds of course - down around 20 or a bit less for the sandy stuff.
AnswerID: 203535
Reply By: ross - Tuesday, Nov 07, 2006 at 23:17
I always run the front tyres slightly higher because the front of most vehicles is heavier due to the weight of an engine/transmission when unladen.
If towing or carrying a heavy load I would inflate the rears to a higher psi.
Ive also found with the rear springs on my landcruiser unladen the lower psi helps with the ride
AnswerID: 203630
Reply By: Black Beard - Wednesday, Nov 08, 2006 at 09:22
I've got 48 in the front and 50 in the back (trayback - REALLY full) Most of my driving is on gravel & I don't have any dramas, even wear & no sidewall splits.
AnswerID: 203658
Reply By: sailor1man - Sunday, Nov 19, 2006 at 02:11
I am running a GU IV the book says 32PSI Nissan says ignore it and run at 36 with no load. Got some advice from a tyre manufacturer a long time ago. The correct way to find out what pressure you should be running is to check the pressure when cold ie first thing in the morning. Then after travelling for at least 40K check the tyres again hot. In a car the tyre pressure should have increased by 4 PSI. If it hasn't the tyres are over inflated, if its increased by more than 4PSI then the tyres are under inflated. The 4PSI rule is for cars, for 4x4 its 6PSI.
AnswerID: 205690
