NM paj brake fuse keeps blowing
Submitted: Friday, Nov 10, 2006 at 21:38
ThreadID: 39322 Views:3615 Replies:8 FollowUps:1
Hi there all! was wondering if anyone has had problems with nm stop lamp fuse. i noticed it was blown while testing trailer lights. thought that could be the problem so disconnected the socket completely. no luck so disconnected rear side lamps and back door lamp, still no luck, fuse blows as soon as brake pedal depressed. do the bumper lights give trouble? also have after market cruise control (2.8l diesel). any advice would be greatly appreciated.
Reply By: obee - Friday, Nov 10, 2006 at 21:44
I can only suggest the switch at the pedal end or damage to the wiring along the way to the rear. Apart form that ... sorry.
Owen
AnswerID: 204210
Reply By: desray - Friday, Nov 10, 2006 at 22:24
You say you have disconnected the trailer socket completely. Have you had a look inside the socket , the wires do come off sometimes.
AnswerID: 204216
Follow Up By: Member - Vince B (NSW) - Saturday, Nov 11, 2006 at 13:51
I had the same problem on my NL pajero.Checked the female plug, rewired it again & problem was solved.
Vince
FollowupID: 464031
Reply By: marq - Friday, Nov 10, 2006 at 22:26
I suggest you post over at forum.pajeroclub.com.au for help.
AnswerID: 204217
Reply By: Redeye - Saturday, Nov 11, 2006 at 06:27
Hi LyalltheCrocodile
Will not directly fix your problem but assist in finding it without blowing 100 fuses.
To save fuses on a fault condition (s/c) you replace the fuse with a 12v low wattage lamp. This will mean that the lamp will glow instead of the fuse blowing every time you press the pedal. Then go through a process of eliination by disconnecting things one at a time until you locate the problem.
When the fault is corrected then replace the fuse.
Redeye
AnswerID: 204237
Reply By: Mark Taylor - Saturday, Nov 11, 2006 at 08:32
Hi there... as an auto electrician, whenever we get a problem like yours, the trailer plug wiring (on the car) is always "faulty until proven otherwise".
It is always the first place to check.
Good luck.
MT
P.S. The test light cross the fuse holder is what we use.. light glows bright - short circuit!
AnswerID: 204248
Reply By: LyalltheCrocodile - Saturday, Nov 11, 2006 at 15:08
thanks all, should have thought about the 12v light myself, being an electrician. anyway went out this morning disconnected the bumper lights (didnt realise it was so easy or would have done it earlier) reinstalled the fuse- so far so good. replaced the rt hand light-no problem, so disconnected the right hand light and connected the left hand one. again no problem connected everything back up and it's all working. Grrrr....i hate intermittent faults. anyway perhaps the connecters were dirty? but the fuse was going with such a 'pop' that it seems unlikely. anyway thanks for the help, see how long it stays working.
AnswerID: 204282
Reply By: SIR GREENDOG - Saturday, Nov 11, 2006 at 15:33
Well let me give you some adive after a very serious incident happened to me in my NH Paj,i keeped on having no brake lights so the fuse keeped blowing so keeped on replacing the fuse,well one day i was driving to work and smoke started caming out from behond the dash and i mean smoke could'nt see the windscreen from smoke,called the fire'es,could'nt turn the engine off,in the end it was becuase the trailer plug wiring drop on to the excaust and cooked it sending heat through to the dash and cooked every thing if you now what i mean very expensive,so my adive would be straight to an auto electrian,do.nt wait any longer or do'nt drive it.cheer's Sir GREENDOG
AnswerID: 204286
Reply By: eazy - Sunday, Nov 12, 2006 at 09:22
Has exactly the same problem on my NM - it took several trips to autoelectricians/mitsubishi before it was diagnosed as........a fault with the trailer wiring!
There are also some posts on pajero club forum which indicate that the fuse has been underspecced and some owners have replaced the existing fuse with the next rating up and solved the problem.
AnswerID: 204361
