New Hilux spottie wiring
Submitted: Tuesday, Nov 14, 2006 at 14:42
John R (SA)
I keep killing my aux batteries. Fortunately the local Beaurepaires keeps replacing them on warranty, but they must getting as sick of it as I am.
While I'm checking a few other wiring setups, I'm querying the spotties relay.
The diagram I use was provided by the local Toyota dealer, and I've posted it here previously.
It certainly works, but the relay is always open and I wonder if that is creating a small but constant drain.
Could a few of you who have negative active highbeam please provide a relay wiring diagram so that I can confirm or change
mine?!
For no apparent reason I've used one of those switches with a small led on the stalk on the dash. Which incidently didn't work in this situation.
I know neither of these factors alone will kill a battery, but the relay wiring is one thing I'd like to check.
FYI, the dual battery system has a pirhana gadget. Running of the aux battery full time are a grn radio, uhf & fridge. Based on discussions on this
forum, I've got a powertech 12/6A charger which quite often I'll plug in overnight.
Reply By: gav99x - Tuesday, Nov 14, 2006 at 15:44
Hi John R, my Jackaroo is negatively switched and I hooked up my Narva's following the advice on this thread:
Site Link
Worked beautifully, on with the high beam etc., and with the ability to switch off independently.
Hope it helps.
204904
Follow Up By: gav99x - Tuesday, Nov 14, 2006 at 15:49
Sorry forgot to mention, if you scroll down to the 3rd post on the second page there is a good description as to what to hook up to which pin on the relay.
464798
