Engine Flush
Submitted: Tuesday, Nov 14, 2006 at 20:06
Happy Chappie
Hi, Has anyone had any experience with 'CEM’s Flushing Oil Concentrate' - that is, Does it work like the advertising says, and is it worth doing or does it cause other problems?
Thanks for sharing your experience,
Chappie
Reply By: Max - Sydney - Tuesday, Nov 14, 2006 at 20:20
Yep - used it on a 7 year old 80 series diesel, and have done the follow up dose every 2 or 3 oil changes.
The oil stays a lot cleaner and its a lot less rough on idle. Impossible to pick whether it saves
fuel - too many other variables, especially as I started hauling a caravan about the time. I bought my second bottle just recently
It's been pretty widely recommended on this site and I saw no negatives at all from anyone before using it.
Worth a bash I reckon. .
Max
204966
Follow Up By: Member - Jack - Wednesday, Nov 15, 2006 at 12:09
Hi Max:
I don't want to hijack the thread, but I have a bottle of it and have not used it yet. I change my oil almost religiously every 5000km. I had the view that regular changes would eliminate the sludge thing in my diesel. Would you think I might get any benefit from using it?
I had previously thought it was for engines that did not get much in the way of regular
services.
Thanks .. and apologies again for the thread hijack.
Jack
465012
Follow Up By: Max - Sydney - Wednesday, Nov 15, 2006 at 18:02
Hi Jack
I'm like you - have changed the oil regularly at 5000 km, and the filter as
well because it gets very heavy in 5000 km. However, after about 2 or 3,000 km, you could stain your fingers on the dipstick.
Since I treated it (Just by putting 125 mm of the FOC into the old oil, run it at fast idle for 30 minutes then drained it, plus regular 25 mm "maintenance doses" just before oil changes), it looks like engine oil till the next change. I can rub the dipstick and not get my fingers all covered with soot the way they used to.
So I reckon the answer is yes - they talk in their literature about soot building up around the back of rings etc, and seem to be right.
Hope that helps
Max
465117
Reply By: Muzzgit [WA] - Tuesday, Nov 14, 2006 at 23:20
I just did a
site search and found quite a few pages on it. Lots are recent too.
205015
Reply By: Member - Ian H (NSW) - Wednesday, Nov 15, 2006 at 07:49
Yes, I have used it and it is great. See the old posts about my experience with it. Seems to be expensive but after the first dose the useage rate is low. despite what nonusers may say, it works
205043
Reply By: Happy Chappie - Wednesday, Nov 15, 2006 at 13:05
Thanks for sharing your experience.
Chappie
205097
Reply By: Alloy c/t - Wednesday, Nov 15, 2006 at 18:39
Works ,nuff said , lots in the archives /search function.
205164
Reply By: Happy Chappie - Thursday, Nov 16, 2006 at 13:21
You have convinced me - I am going to try it.
Will probably get the twin pack - the FOC and CleanPower
with thanks - from Happy Chappie
205314
