12 volt socket
Submitted: Wednesday, Nov 15, 2006 at 21:34
Member - Andrew W (VIC)
Is 4 mm wire sufficient to connect a cigarette type socket (for a 40 watt Waeco wine fridge)? - and do I need a fuse in the line or can I connect it direct to the battery terminals in the van?
Reply By: Derek from Affordable Batteries & Radiators - Wednesday, Nov 15, 2006 at 21:47
4.8mm2 Tinned max 5m run.
6.0mm2 Tinned better.
Use a breaker. Better than a fuse. Don't try it with out a fuse or breaker.
Regards Derek.
205204
Follow Up By: Gronk - Thursday, Nov 16, 2006 at 14:10
Just to clarify Dereks post, -- 6mm2 conductor, not overall wire size !
Too easy to get the two confused ?
465283
Reply By: Member - Tonester (VIC) - Wednesday, Nov 15, 2006 at 23:56
Thanks for the info too. Got a 50lt Waeco and battery etc being done next week by batteryworld. They seem to know their stuff but will keep an eye out.
205240
Reply By: PhilZD30Patrol - Thursday, Nov 16, 2006 at 08:26
Hi Andrew
The great majority of fridge problems can be traced back to the cigarette type fittings. Even the so called heavy duty ones are unreliable in the medium to long term because these fittings rely on spring tension for a low resistance connection. Unfortunately loose their spring tension due to constant vibration especially on rough roads.
Get your auto electrician to install quality connection system and don't chase a bargain as you get what you pay for.
Use 6 mm wire for +ve and -ve. What goes in must come out. Ensure -ve connections are clean and tight. Protect the installation with a good fuse or better still a circuit breaker.
Keep the cable run as short as possible because the length of cable run equals voltage drop. !2 volt DC systems are potentially very unreliable if not installed correctly maintained by ensuring all connections are clean and tight.
Good luck
205266
Reply By: Wingwang - Thursday, Nov 16, 2006 at 12:25
if you are not prepared to pay $50 for a decent low current circuit breaker you are better using a blade fuse.
205308
Follow Up By: Member - Stephen M (NSW) - Friday, Nov 17, 2006 at 15:27
Hi there Wingwang, what size fuse would be suitable, I am running a 50 L waeco. I am running it direct from the battery to inside the cab. I already have it hooked up but was always wondering what size fuse I should have in there. It has a 20amp blade fuse at the moment same as whats in the cigarette lighter ?? Regards Steve M
465467
