GU Patrol Suspension
Submitted: Friday, Nov 17, 2006 at 10:08
ThreadID: 39529 Views:2033 Replies:6 FollowUps:1
The suspension in our 1998 GU Patrol requires a bit of an overhaul. The mechanic mentioned that the rubber bushes are starting to develop splits. Does anyone have any recommendations.
Reply By: Robin - Friday, Nov 17, 2006 at 10:26
Stick with genuine or at least rubber bushes as replacements.
Robin Miller
AnswerID: 205440
Reply By: Semps - Friday, Nov 17, 2006 at 10:27
Hi Robin, Thanks for your recommendation
Amanda
AnswerID: 205443
Reply By: Member - Roachie (SA) - Friday, Nov 17, 2006 at 10:34
May I ask, what bushes was the mechanic talking about?
It could be the bushes at either end of the shockies? Or the 4 castor bushes (front end) or the upper or lower trailing-arm bushes (rear end)? or it could possibly be the bushes in the front &/or rear Panhard Rods? or, on the front, there is also the possibility that the trailing arm bushes could be shot? So many bushes to choose from.....
AnswerID: 205446
Follow Up By: Truckster (Vic) - Friday, Nov 17, 2006 at 10:36
I hate going to the dentist for a haircut.. hate too many bushes
FollowupID: 465432
Reply By: Semps - Friday, Nov 17, 2006 at 10:42
Obviously I am not very mechanical, but the mechanics reports says...
Splits developing in front radius arms (suspension to front differential housing) bushes.
AnswerID: 205449
Reply By: ingo57 - Friday, Nov 17, 2006 at 14:51
I have replaced suspension bushes with nolathane bushes (hard compound rubber/plastic) on previous 4WD's and IMO found them to be excellent, does any one have a difference of opinion?
AnswerID: 205480
Reply By: junior - Saturday, Nov 18, 2006 at 00:41
Hi Semps, I agree with Robin on this. Urethane will last longer in your raidius arms but will not flex like the original rubber ones. Don't know if you have a lift... if not, you may find it tricky to find non-offset (caster correction) urethane bushes anyway. Genuine are from memory @ $50 per (x4)= @ $200!!! Yikes!... been there, done that, gunna have to do every couple of years too!
AnswerID: 205559
