Jayco Jockey Wheel
Submitted: Friday, Nov 17, 2006 at 15:27
Dave Thomson
Hi All, just put a new swing away jockey wheel on the freedom {02}, for sway bar clearance, I've had to set it back a fair bit {nearer the van front} is that O.K. ? cant really see how else it can be done any advice is always good,
regards,
Dave
Reply By: Penguin (NSW) - Friday, Nov 17, 2006 at 16:49
Hi Dave
I've seem some vans with the jockey wheel mounted to the inside of the A-frame. Not sure if you'd have the clearance for a swing-away type.
Mike
205499
Reply By: hoyks - Friday, Nov 17, 2006 at 17:26
I can't see a problem other than it may be a bit heavier to wind it up and down as you have less leaverage.
Inside the A-frame would be good, if you have clearence from brake cables and the sway bars, as then you would be less likely to bash your leg on it.
205501
Reply By: Dave Thomson - Saturday, Nov 18, 2006 at 16:20
Yes thanks for that guys, unfortunately my backs crook so pulling it from the inside would'nt be good for me {funny position} but I think its safe to say it should be O.K. where it is, but thanks anyhow,
regards,
Dave
205623
