Locking external battery box to CT battery tray
Submitted: Wednesday, Nov 22, 2006 at 17:01
Member - Tonester (VIC)
All, just bought a battery box for the CT, and it is to sit in the supplied tray at the rear left of the CT, just behind wheel arch. Its external. I can easily tie it to the CT battery tray using straps but I want to be able to lock it down securely (theft).
Are there any devices out there? A search didn't turn up anything obvious. Or maybe just a light chain & padlock?
Reply By: Shaker - Wednesday, Nov 22, 2006 at 17:08
In the past, we have up a hinged stainless steel strap with an over centre type clip that has a padlock hole, available from boat chandlers.
206407
Follow Up By: Member - Tonester (VIC) - Wednesday, Nov 22, 2006 at 19:27
Thanks Shaker. Will make some calls.
466352
Follow Up By: Shaker - Wednesday, Nov 22, 2006 at 23:30
should read .... we have made up ......
466413
Follow Up By: Member - Tonester (VIC) - Thursday, Nov 23, 2006 at 19:46
ah. bugger!
Had a squiz at bunning today, and nothing easy or obvious unless I learnt to weld.
466545
Reply By: Member - Uncle (NSW) - Wednesday, Nov 22, 2006 at 18:01
Hi Tonester, we have ours like this, probably similar to shaker's by the sound of it??!MPG:31!
206416
Thanks Uncle. Bought, or custom made?
466353
Follow Up By: Member - Uncle (NSW) - Wednesday, Nov 22, 2006 at 21:48
It was designed by the guys that made the camper, simple but rather effective.
466382
Follow Up By: Member - Uncle (NSW) - Wednesday, Nov 22, 2006 at 21:51
Forgot to mention there is a small hinge on the bottom, it's a bit hard to see.Great set up how the strap just swings down and out of the way so we can access the battery to put the solar panel clips on.
466383
Follow Up By: Shaker - Wednesday, Nov 22, 2006 at 23:31
yes, that's similar.
466414
