Waeco fridge basket
Submitted: Thursday, Nov 23, 2006 at 22:26
RayJen Paj05
Hi all: just back from
Vic High Country with JohnR (Vic) & Moses, Des Lexic and Blaze:
while cleaning gear have noticed that a few small sections of the fridge basket have friction wear on the white rubber-like coating. Any ideas on what to use to prevent what might be eventually expected: rust patches??
Thanks and all the best, RayJen
Reply By: Willem - Friday, Nov 24, 2006 at 00:24
I am surprised that you survived the ordeal with those old buggers as company.....hahahaha
You could try a dab of white silicon rubber on the marks.
206640
Follow Up By: handy - Friday, Nov 24, 2006 at 07:29
try what willem has suggested and in future put a towel under it as
i use the towel for 2 reasons, 1 to stop the rubbing and 2 as i have the 110lt model the towel sucks up any moisture. why they dont put a bung in these big ones has got me stuffed. cheers
466619
Follow Up By: Member - andrew B (Kununurra) - Friday, Nov 24, 2006 at 13:21
Gday Handy
Good point about the lack of a bung - the little sponge under the flap (80l) is quite laughable!
Cheers Andrew
466668
Reply By: RayJen Paj05 - Friday, Nov 24, 2006 at 08:39
Thanks Willem & Handy.....yes, we were lucky to survive!
206660
Follow Up By: Des Lexic - Friday, Dec 01, 2006 at 22:49
BS!!!!!! You survived cos you had expert guidance and advice.
468007
Reply By: Member - Arkay (SA) - Friday, Nov 24, 2006 at 08:59
After returning from the Kimberleys we found that some of the vertical wires were rubbing on the inside lining of the fridge too, especially near the top lid hinge end. This left the nice white paint a bare silver colour. 40 litre FF40 model. What I did was to get some soft clear tubing similar to fish
tank air supply tubing, cut appropiate length strips that would fit between the horizontal bars in the relevant place/s, then carefully cut the pieces of tube down the middle lengthways, and clip them around the vertical bars. 2 strips sufficed as they then gave the whole side of the basket a bit of clearance from the white lining. Bit amateurish, but it worked.
206662
Follow Up By: Member - Willie , Epping .Syd. - Friday, Nov 24, 2006 at 10:47
Great idea , I will do it to
mine .
Thanks ,
Willie .
466637
