1HZ Troopie Gearbox jumping out of gear
Submitted: Friday, Nov 24, 2006 at 16:49
Skid
I was recently cruising along after doing some hard bush work for 5-6hrs on a hot day 35' ++ when 5th started jumping out of engagement on overrun.
Box has done 300.000 with no problems. Oil is 5000kms old Penrite and at normal level.
Next day did 400kms on bitumen without it happening again.
Have I got a upcoming problem with the gearbox?
Is this typical Troopie
warning sign?
Would apreciate any comments
Reply By: Peter 2 - Friday, Nov 24, 2006 at 19:13
It could be that the gearbox is worn and the extra heat caused it to play up.
It could also be asign of problems with the main shaft and transfer input gear wear which will if it happens stop all forward motion.
the wear on the main shaft and input gear can be checked by removing the PTO cover on the transfer, hold the main shaft (jam it with something, wood etc) and see if you can move the input gear on the shaft, if there is any appreciable rotary movement in the splinesbetween the gear and shaft then you will need to fix it.
At 300k I'd expect a full rebuild on both gearbox and transfercase.
206742
Follow Up By: Angler - Friday, Nov 24, 2006 at 21:23
I reckon this is par for the course, most of the early five speeds did this. I found if you put it in fifth under a bit of power it seems to stay put. Drop it in with engine at 500rpm and slowly let the clutch out and it will drop out fairly often.
Pooley
466729
Reply By: 666toy - Saturday, Nov 25, 2006 at 01:40
REBUILD TIME NOW...don't wait for it to get worse . you most likely have a worn input gear & shaft 300,000 is a good innings for a L/C box.Cheaper to fix now than when its completely stuffed.
206793
Reply By: Member - Doug T (W.A) - Saturday, Nov 25, 2006 at 21:46
Mine was jumping out of all gears when lifting foot off the go pedal. I put up with it for near 12 months , just had to put my hand on it going down hills etc, until at about 530,000 ....KAPUT
Doug
206890
