Monday, Nov 27, 2006 at 09:29
I had my dieselgas fitted late September 2006. Unfortunately I haven't had the opportunity to cover any big rough 4wd trips yet so it is still early days.
The 30 ltr LPG
tank is mounted underneath on the inner LHS in front of the rear axel.
Ground clearance is reduced very slightly by the strong protection plate under the
tank.
The exhaust system had to be re-routed to make room for the LPG
tank
The 2nd diesel
fuel tank remains untouched. This means I now carry about 140 to 150 litres of usable
fuel.
Diesel Gas Technologies in Coxs Avenue Kingswood Penrith NSW did the installation. They are very good to do business with. Their communication with the customer is friendly and informative. The finished work looks professional.
Performance is definately improved, especially moving from standstill to about 70 kph and up hills. The engine starts instantly and is smoother and quieter.
Exhaust noise vibration has increased slightly, I suspect this is as a result of the relocation work on the exhaust system. I don't find this to be a problem.
Overall
fuel use has not altered at 12.1 litres per 100 kms.
Now using about 9.6 litres diesel and 2.6 litres LPG per 100 kms. I have only traveled about 1,200 kms since the 1,500 kms service & final adjustment so, as I said, it is still early days.
I find I am now moving away from stand still and traveling faster than pre-LPG installation days despite my best intentions. I suspect my wife may go faster still as she is always in a hurry!
The Government rebate of $2,000 was paid within 14 days.
Payback will take many kilometres and will depend on the price of diesel. I note that the financial wizz kids are saying that the oil prices will increase again as the Northern hemisphere winter sets in and the current easing of oil prices is very temporary.
I had LPG fitted to save
fuel costs and reduce exhaust emissions as an attempt to do my bit for the environment. I try to be a greenie.
From my research I believe that the LPG injection can increase combustion efficiency, reduce exhaust gas temperature and carbon build up in the combustion chambers. Hopefully this may reduce the chances of premature engine failure as experienced by so many unfortunate owners of the ZD30. Only time will tell and I will celebrate when/if I get to the 250,000 kms without engine failure.
Search the Google Australia for dieselgas and dieselongas web sites for more info on running diesels on LPG. European search engines like Ask Jeeves also have diesel LPG information.
Hope this answers your questions
207067
