1999 GU Power Problem
Submitted: Sunday, Nov 26, 2006 at 15:57
ThreadID: 39787 Views:1896 Replies:2 FollowUps:2
Hiyas, i am having problems with my Patrol, when the key switch is put into the ignition position all my power drops out and nothing can be done to get it back. when i remove the ECU fuse No.25 from holder some power comes back but still looks dim. All the clocks reset and no power at all. There is no key reader installed there was an imobiliser but have since removed that but no joy.
Any help would be greatly appreciated
Reply By: Notso - Sunday, Nov 26, 2006 at 16:03
Crook Battery,
Resistance on the battery terminals.
Do your headlights come on bright?? Without the ignition on??
AnswerID: 206962
Follow Up By: Tate - Sunday, Nov 26, 2006 at 16:13
narr as soon as the lights are turned on the thing dies and looks like only 4 volts getting to the fuse box inside the car. battery all good. looks like i got a fun afternooon looking for a hot joint.
thanks for that
FollowupID: 466937
Follow Up By: Junior - Sunday, Nov 26, 2006 at 16:45
double check the battery terminal connections- especially check the earth- take off both and clean terminals and connectors- I had similar prob recently when I changed batts- cleaned up earth connector till I saw fresh brass again, and now all good.
FollowupID: 466941
Reply By: Tate - Sunday, Nov 26, 2006 at 17:31
found the fault, the negative cables from the battery to the chassis were not making good contact, as i have modified the wiring a bit of dirt or something got between them all good now
thanks for your help
AnswerID: 206970
