Lucas diesel fuel filter for patrol........where can i get this?
Submitted: Friday, Mar 21, 2003 at 23:05
IAMGQ
Currently using valvoline
fuel filter. Have a Nissan genuine as spare but don't know if it is better than valvoline.
Also, how good can lucas filter is except it can show us the
water level in filter ? Where can I get this in Dandenong area and how much ?
Thanks for any advice !
Reply By: Member - Topcat - Saturday, Mar 22, 2003 at 00:23
If you have a Coventry Dealer in your area try them as they deal in Lucas Filter accessories. Have
Wheels Will Travel
15827
Reply By: Scott - Saturday, Mar 22, 2003 at 13:36
Use a Ryco filter and stick to your original Nissan unit as it does have a light to tell you as soon as
water is in the filter housing. Chances of getting
water is slim today in diesel unless you are using drum
fuel that is not cared for correctly. Without the light in the Lucas unit you could get a full dose of
water not knowing it was there. With your Nissan original unit the light will come on while you are driving. I have seen this scenario twice with people that have changed from their original filters.
15850
Follow Up By: IAMGQ - Saturday, Mar 22, 2003 at 23:00
Thanks Scott
You just point out an important factor which I haven't considered. Thank
9696
Reply By: Eric - Saturday, Mar 22, 2003 at 22:40
Iamgq.
THe lucas or cav filter is designed for tractors where the
fuel tank is above the filter and there is always a slight positive presure, If you use them as a suck threw filter they may not allow enough
fuel to you motor. I recomend using the factory filter becuse of the light and you will need it for the primer pump. The only way to use the cav is in line with a transfer pump. Eric.
15890
Follow Up By: IAMGQ - Saturday, Mar 22, 2003 at 23:05
Thanks Eric,
from what you say, Lucas/Cav filter has filter element which is finer than other aftermarket / genuine filter (i.e. <10micron)? If so, shouldn't it be better ?
Haven't heard ppl using it with lacking of
fuel supply...........
9698
Reply By: Truckster - Sunday, Mar 23, 2003 at 18:40
www.dencodiesel.com sell em too.
15919
