Will it run it?
Submitted: Saturday, Dec 02, 2006 at 21:21
ThreadID: 40000 Views:4021 Replies:4 FollowUps:3
I have been told the Honda 2.0 will run the 'Dometic' caravan air con with no problems.
I have read somewhere the start up watts can be as high as 4500watts. So with the Honda being 2000watts I am having some doubts what its peak is.
or is it not that simple?
Do I need an invertor to make up for the watts on start up.
Does anyone have this particular model of air con and uses a Honda 2.
Reply By: ZukScooterX90 (QLD)Member - Saturday, Dec 02, 2006 at 21:38
John,i went through this about 12mths ago,although i am not sure what brand my aircon is i think it maybe the same.Anyway so to be sure there were not going to be a issue i bought the larger Kipor the 3 with the inverter i have not been able to use it while away as of yet but i have tried it at home & runs it without any hassels.If you can borow or hire one of the Honda's to try before you buy would be a good idea.If you can get hold of one then crank it up (the aircon) to max for an hour or even half an hour to see how it go's.Good luck with it.:o))
Bob.
AnswerID: 208235
Reply By: Derek from Affordable Batteries & Radiators - Saturday, Dec 02, 2006 at 22:03
H Ozdyssey
I have the Honda eu2.0 and it runs my Heron 2.2 and have no problems.
Here are the specs...
General Specifications
Heron 2.2
Electrical Rating (single phase) 240V, 50Hz
Nominal cooling capacity 2.7kW
Nominal heating capacity* 1.5kW
Maximum rated current - cooling 4.0A
Maximum rated current - heating 6.5A
Maximum L/R current 20A
Maximum air delivery 110 l/s
Installed weight 34kg
* for Heron 2.2 this is delivered heating output
Not sure of the Dometic specs.
Derek.
AnswerID: 208241
Follow Up By: Rob - Sunday, Dec 03, 2006 at 10:30
Hi Derek,
Are you able to run your Honda eu2.0 and Heron 2.2 with the eco throttle switched on?
In my case (with the same setup), unless the generator is running full throttle, the Honda cant "spool" up quick enough to meet the startup power requirement of the Heron 2.2, it goes into overload protection mode.
Thanks,
Rob
FollowupID: 468222
Follow Up By: Derek from Affordable Batteries & Radiators - Sunday, Dec 03, 2006 at 11:26
Hi Rob,
I run the Honda on normal mode. It has cut out once or twice when on eco so now when I run the a/c I leave it on normal.
Derek.
FollowupID: 468228
Reply By: Motherhen - Saturday, Dec 02, 2006 at 23:32
Hi John - i have replied again on the caravaner's.
AnswerID: 208255
Follow Up By: Member - Ozdyssey (QLD) - Sunday, Dec 03, 2006 at 07:26
thks MH
FollowupID: 468209
Reply By: Member - JohnR (Vic)&Moses - Sunday, Dec 03, 2006 at 20:36
John, have a Dometic B1900S and it is powered quite well with a Honda EU20i on eco throttle. I understand that the manufacturer will only provide the guarantee with the Honda unit for stability and surge. The Honda was charging the battery at the time too and running the fridge. :-0
I don't know what the starting current requirement is to compare.
AnswerID: 208382
