EGR Trial
Submitted: Monday, Dec 04, 2006 at 09:28
Snowy 3.0iTD
After having had the EGR pipe blanked off at the inlet manifold for about 2 months now on my 2003 3.0L Patrol, I have noticed the following results:
- At highway speeds the boost gauge now shows less boost, at 110km/h it is down from 8-12psi to 4-8psi (at the intercooler outlet)
- The turbo spins up slightly faster when I put the foot down.
Fuel consumption is down from an average of 14L/100km to 13.5 average
Other things that affect the
fuel consumption on my Patrol are 33"MTR's, a 2"
suspension lift,
snorkel and DTronic. I also figure that not feeding hot/sooty exhaust gasses back in to the engine has to be better for it, so it will be staying blanked off.
Snowy
Reply By: Member - Captain (WA) - Monday, Dec 04, 2006 at 11:23
Hi Snowy,
I have been watching these posts with interest and I now reckon its time to do
mine. Did you just use a "full" gasket to blank off the EGR and if so, what material? Also, any special tricks in actually doing the job or is it pretty straightforward?
Captain
208473
Follow Up By: Snowy 3.0iTD - Monday, Dec 04, 2006 at 11:42
I just took a spare gasket in to the local sheet-metal place and had one without
the big hole made out of 1mm stainless steel plate. It cost me $20 and they reckoned that standard galvnised plate would have been okay but I went for stainless for peace of mind.
It took me about 40mins to do but is pretty straight forward; you unbolt the intercooler cover, unbolt the intercooler you can try pushing it aside but I found it easier to undo the hose clamps and totally remove it. Unbolt the pipe from the EGR valve where it feeds in to the inlet manifold and gently pull it back. Take out the old gasket, and clean the excess gunk from around the area. I put a thin bead of sealastic on both sides of the plate, but make sure it is only a clean thin bead, particularly on the inlet side as you don't want a glob of silicon breaking off at some stage and blocking a valve. You then bolt everything back up, the reverse of the above described procedure. If you are still unsure, if you have one one of the CD-ROM workshop manuals they have an exploded view of this area, if not you can email and I can send you the relevant pages in a PDF in the next day or so.
Snowy
468459
Follow Up By: Member - Captain (WA) - Monday, Dec 04, 2006 at 11:56
Thanks for that Snowy, much appreciated. And yes, I would appreciate the relevant pdf ppages when you get the chance (my email is in my rig profile).
Captain
468461
Follow Up By: hl - Monday, Dec 04, 2006 at 13:19
There really is no need to take the intercooler off. Not even the cover, really.
When you undo the 2 bolts, the casket falls out as soon as you pull the pipe back.
You can just slide the plate in, line up the bolt holes, and Bob's your uncle.
Taking the plastic cover off does make it a little bit more accessible, but if you had any midwife training, you won't need to do it.
That way it takes about 5 minutes to do (and to reverse).
468471
Follow Up By: Snowy 3.0iTD - Monday, Dec 04, 2006 at 13:27
hl
That may be true for some, but as I have large paws rather than the delicate double jointed hands of a surgeon, I found it essential to remove the intercooler cover, and although not essential removing the intercooler certainly made it easier. It does take longer, but as my 4BY is my second most valuable asset I am quite happy to take a bit longer and make sure I get it right.
Snowy
468473
Follow Up By: cam_champion - Monday, Dec 04, 2006 at 14:37
another point of note, those of us with manual 3.0L and WITHOUT a d-tronic that have blocked our egrs have had some issues with the vehicle going into 'safe' mode at highway cruising sppeds. noted by a sudden lack of power occasionally. The fix for this is to adjust the VNT limiting screw down by about 1/3 of a turn on the turbo to limit peak boost. Note, this only limits peak boost and no of us have noticed any difference in real world driving. This will reduce peak boost by 1-2 psi and stop it going into 'safe' mode. Also note that this does not bring on the engine light!
468495
Follow Up By: Member - Glenn D (NSW) - Friday, Dec 08, 2006 at 21:40
Hows it going Cam ,
Having been plauged by ' safe mode ' problems , I am just wondering how you know that this is your problem without the 'check engine' light coming on , also what is the difference between having a Dtronic fitted and not?
How have you come across the adjustment that you prescribe ?
Glenn.
469354
Follow Up By: cam_champion - Saturday, Dec 09, 2006 at 14:17
for me when the fix, whilst driving, was to back off and then reaply the accelerator, this indicated that it was an electrical problem and a fairly minor one (though very frustrating) and my first port of call was to replace the MAF sensor. Problem still existed, but happened less frequently. The patrol4x4.com forumites (chaz mainly) have discussed similar problems that had arisen with their patrols after the egr had been blocked. It seams to be a case of peak boost rises slightly once exhaust is not being re-dirrected back into the intake manifold via egr valve. the rise in boost is enough to trigger a "safe mode" situation but not enough to cause the ecu to fault and bring on the check engine light. The fix of lowering peak boost was discussed thouroughly and it would seam that blocking egr's is common with the european spec engine, and an article that was posted on the patrol
forum (in french) initially provided us with the details of lowering peak boost. This has been a fix that has not seen
mine go into 'safe mode' since, egr is still blocked, and in the real world of diving there has been no noticable loss of power.
469462
Follow Up By: cam_champion - Saturday, Dec 09, 2006 at 14:19
none of us are sure why this problem does not exist if there is a d-tronic fitted, best guess is that there are different boost parameters programmed into the d-tronic.
I am also hoping that the slightly lower boost will help with the longevity of the engine as I was hoping to get at least 300,000ks out of
mine.
469463
Reply By: Redback - Monday, Dec 04, 2006 at 13:28
Standard mod for TD5s in the UK is to blank off the EGR, their are the same about puuting hot gasses back into an already hot engine, you can even buy a kit for the TD5 to do it.
I would assume the Nissan 3.0ltr would be much the same design as the TD5.
Baz.
208490
Reply By: Muzzgit [WA] - Monday, Dec 04, 2006 at 14:57
Yep. had
mine done while it was in for the 120k service. Turbo spools up a bit earlier [yay, less turbo lag] and
fuel comsumption is down a tad.
208506
Reply By: awill4x4 - Saturday, Dec 09, 2006 at 16:00
Caterpillar diesel engines have gone away from the "egr" method of controlling the oxides of Nitrogen to their new "acert" technology that controls the emissions without having to introduce dirty exhaust fumes back into the intake system.
Eventually, this will probably be the way most manufacturers will control their diesel emissions.
Regards Andrew.
http://www.cat.com/cda/components/securedFile/displaySecuredFileServletJSP?fileId=279299&languageId=7
Site Link
209458
