POINTS REPLACEMENT
Submitted: Saturday, Dec 09, 2006 at 20:18
ThreadID: 40215 Views:2250 Replies:5 FollowUps:0
Any one know who manufactures a electronic points replacement for a 3f Toyota eng?. Repco used to stock them but haven't for some time as did Coventry.
Any help welcomed....666TOY
Reply By: Member - Mike_L (SA) - Saturday, Dec 09, 2006 at 21:13
Jaycar do a kit, you have to build it of course so soldering skills will be needed!
Site Link
Mike.
AnswerID: 209519
Reply By: Wok - Sunday, Dec 10, 2006 at 07:47
I had an Allison Hall effect unit in mine but that company got taken over [can't remember the new name :(] Got replacement lead from Autobarn [Brisbane Virginia]....thought Snake racing was the agent but can't find it on their website
............old timers disease is catching up too quickly :(
eng
AnswerID: 209561
Reply By: Boldor - Sunday, Dec 10, 2006 at 20:04
Piranha used to do electronic ignition kits. I had one I fitted to a 2f, then a 3f. The same unit titted the 4cyl. hilux, only with a 4 slot disc instead of 6. I had many years of reliable service with it, and no points adjusting. I only recently sold the 3f motor and let it go with it. I Fitted a 1HZ diesel to my 62 series wagon.
AnswerID: 209638
Reply By: 666toy - Tuesday, Dec 12, 2006 at 11:07
Thankyou for your replys everybody. I have had some luck with a USA company called PERTRONIX after some ringing around i found a company that sells them here in Aus. The only problem was they wanted to charge me $250.00 + delivery now i checked a USA website that sells PERTRONIX & they can ship it to me for AU$120.00 deliverd. I think somebodys getting a little greedy !
...........666TOY
AnswerID: 209937
Reply By: galfeysteve - Wednesday, Dec 13, 2006 at 21:53
HI,Dick smith used to make a kit for under $100 which was transistor assisted points set up.You still retain your points but all they do is switch a milliamp type current to a giant transistor which then carries the working current of the ignition system,point vertually last forever, only the rubbing block continues to wear and you regap points every 20 odd thousand ks.I made it up and used it for 10 years until it went bung one day and all i did was unplug a couple of wires and bypass back to points only.Hall effect sensors are beaut until they dont work one day in the middle of nowhere.steve
AnswerID: 210252
