Nissan Patrol GU - Long Range TR59 Replacement Fuel Tank
Submitted: Tuesday, Dec 12, 2006 at 21:30
shaen
Evening all,
Has anyone replaced their aux
tank (30 ltr) on a 05 GU 4.2 with a Long
Ranger TR59 (145ltr aux replacement)?
If so any probs with the setup of
fuel between tanks (transfer to the main),weight distribution when fully loaded, the affect on stability and RTA issues (Approvals if required re: weight.)
From the pics on the web site no bash plate is included. Can the unit handle the occasional knock and constant vibration of corrugations?
And thanks
Reply By: Member - Roachie (SA) - Tuesday, Dec 12, 2006 at 21:55
I think you might be a bit mixed up there champ...?
The Patrol has 2 tanks: main is 95 litre and sub is about 35 litre.
You can get aftermarket tanks of 145 litre and around 70 to 80 litre respectively (depending on which manufacturer you go to).
So, you can't replace a 30 litre
tank with a 145 litre
tank.
AFAIK there is no issues with the various authorities about legallity of fitting any of these aftermarket tanks.
I ran the 145 litre Long
Ranger tank in my Patrol for 210,000klm with a few "big" trips and had no worries.
210039
Reply By: shaen - Tuesday, Dec 12, 2006 at 22:04
Roachie,
Check Long
Ranger web site as they detail the TR59 Replacement
Fuel Tank for the aux
tank.
210044
Follow Up By: Truckster (Vic) - Tuesday, Dec 12, 2006 at 22:12
Site Link
Dude, the main
tank gets replaced with a 145 as roachie says.
If you could fit a 145 to replace the aux, it would be sitting on the ground.
145L Replacement
Fuel Tank LWB, GU Cab Chassis / LONG
RANGER
70L Replacement
Fuel Tank LWB, Diesel Only / LONG
RANGER
470067
Follow Up By: Member - Roachie (SA) - Tuesday, Dec 12, 2006 at 22:14
Okay, I think I've found what you're referring to. It's a printing mistake; has to be.
Site Link
It actually says sub
tank holds 147 litres. Impossible!
470068
Follow Up By: Truckster (Vic) - Tuesday, Dec 12, 2006 at 22:16
I think you will find that they haev copied and pasted from one
tank(the one above the T59) to the T59 to save typing and forgot to change it.
Site Link
their FAQ isnt confidence inspiring
TR59 -
Tank has broken mounts
A: The original body mounts have been known to collapse after a rough trip to the cape and the body had come down and was resting on the
tank.
470069
Follow Up By: Leroy - Tuesday, Dec 12, 2006 at 23:23
I'm not a fan of long range tanks since
mine failed on the way back from the cape. When talking to a mechanic in
Weipa he said it's quite common for aftermarket tanks to fail.
Leroy
470076
Follow Up By: Truckster (Vic) - Thursday, Dec 14, 2006 at 13:06
I emailed em, and got a reply making us all out to be on drugs from a daryl...
But they failed again to take their feet out of their mouths - they still havent changed the measurements of the
tank - both are
miles different having fitted a couple to mates cars or helping fit em.
I'd
shop elsewhere.
470329
Reply By: Member - Teabag (Queanbeyan) - Tuesday, Dec 12, 2006 at 22:14
Mate,
I have replaced both tanks and am now running a 145ltr Main and 70ltr Sub which where provided by Longranger Tanks. The vehicle is a 2006 4.2TDi Nissan Patrol Wagon. Have had no noticeable issues though I'm running extra heavy duty coil springs with 2inch lift in the rear and Poly Air Bags. The tanks are tucked up out of the way and appear to be fairly strong. I also had the same set-up on my last GU Patrol with no issues. Feel free to send me a PM if you want further details or even pictures?
For the record: the Main 95ltr
Tank is replaced with a 145ltr and the 30ltr sub is replaced with a 70ltr sub. Thus 215ltrs in total......
210047
Reply By: shaen - Wednesday, Dec 13, 2006 at 06:13
Thanks all I think I wil stick to the jery cans.
210078
Reply By: shaen - Wednesday, Dec 13, 2006 at 06:24
Try jerry
210079
Reply By: flappa - Wednesday, Dec 13, 2006 at 09:02
I have a 70l LR
tank on my Petrol patrol when I changed over to gas.
210099
