fuel filter change on a diesel
Submitted: Friday, Dec 15, 2006 at 20:59
GQ_TUFF
Hi all, I am going to change the
fuel filter on my 2.8 GU tomorrow, this may sound stupid but is there any special things I should be aware of? as I have never owned a diesel before so I just wanted to check.....EG priming afterwards. I have changed hundreds of filters on petrol cars just never a oil burner. Please be kind with your responces as I am sure some will be slapping their heads and thinking its just a
fuel filter for crist sakes.
Thanks Stefan
Reply By: Gob & Denny - Friday, Dec 15, 2006 at 21:06
goodday stefan
just make sure you pump the primer till its hard my gu you pump and think its right and then it stops and you have to start again
steve
210548
Reply By: Member - Axle - Friday, Dec 15, 2006 at 21:28
Hi Stefan
To make things easy, fill the new filter with diesel before fitting, couple pumps on
hand pump and should be sweet.
Cheers Axle.
210554
Reply By: crusher - Friday, Dec 15, 2006 at 22:36
Not familiar with that mode or filter just make sure you ade your dirty
fuel up stream from the filter
Regard
crusher
Ps Happy Xmas
210571
Reply By: hoyks - Saturday, Dec 16, 2006 at 09:52
And be prepared for it to run like a hairy goat and blow lots of smoke for a bit when you start it up. Give it a minute or two and it will settle down.
When priming, I disconnect the
fuel line that goes to the motor and pump the primer until
fuel comes out the hook it all back up again. It seems to prime easier this way and you know for certain that
fuel has got that far at least.
Rubber gloves are a good idea too as you will get
fuel everywhere taking the old filter off, no matter how careful you are. The disposable ones work, but tend to tear on a that hose clamp you never knew was there.
A cheap metal strap type oil filter wrench can also help when taking the old one off and tightening the new one when your hands are covered in
fuel.
Have fun.
210630
Follow Up By: GQ_TUFF - Saturday, Dec 16, 2006 at 11:22
thanks all who replied......off to go get dirty!!
470669
Follow Up By: GQ_TUFF - Saturday, Dec 16, 2006 at 12:20
Bloody hell what was I worried about? 10 mins done.....remove, install, prime, start first go....too easy. Thanks again all who replied as I combined the responses and it worked a treat. Thats why I love this
forum you get the experience from so many and that makes it easy for some one who hasn't done a paticular job before.
Cheers Stefan
470675
