When pulling something apart, & that little chit flys into orbit !!.
Submitted: Friday, Dec 15, 2006 at 22:34
ThreadID: 40389 Views:3099 Replies:9 FollowUps:5
Hi.
How many times have you been dismantling something, and next minute something flys into orbit, or drops in the dirt, and your not even sure what the hell it was. Just pulled the recoil starting mechanism off a old mac whipper snipper.
I think i will have to jump on the next space shuttle to look for all the bits that flew out of the bloody thing.
Pi....ed off Axle.
Reply By: Member - Michael J (SA) - Friday, Dec 15, 2006 at 22:48
Yep Axle,
I can so relate to that. I reckon I have 'lost' more tiny springs/little clips/ball bearings than I can shake the proverbial stick at.
Spent so much time looking for stuff that I bought a dirty great big magnet.
Never found all the little bits, but did find all manner of beer tops/nails/old split pins dah dah dah dah.
Lucky I don't charge myself by the hour........LOL
Michael
AnswerID: 210574
Reply By: Willem - Friday, Dec 15, 2006 at 22:54
I was having fuel problems with the old G60 about 100km west of Broken Hill on the main drag.
I decided to pull the carby to bits in the side of the road. I did just that and when putting the lot back together again I dropped a circlip into the dirt. There I was crawling around under the truck looking for it as it was the one which held the throttle lever on to the carby.
A nice young fella stopped and offered help. He turned out to be a Toolmaker from Roxby and with s bit of wire he manufactured a cirlclip in about 10 minutes flat.
Definitley saved the day. He didn't even give me his name and took off with a wave.
But yes, I have dropped many things like that. Sometimes I find them a year later in a coner of the shed or under something and say..."Wots this?"......LOL
AnswerID: 210577
Follow Up By: Member - Axle - Friday, Dec 15, 2006 at 23:06
Willem , That was a lucky day!! If it had been me, I would still be there looking.
Cheers.
FollowupID: 470609
Reply By: crusher - Friday, Dec 15, 2006 at 23:12
HI that is why you don' do any repairs in remot erares that are not nesarsary.
(dont fu**K around in the bush).
Crusher
AnswerID: 210579
Reply By: Shaker - Friday, Dec 15, 2006 at 23:13
They don't call them "Jesus" clips for nothing!
AnswerID: 210580
Follow Up By: Member - Brian H (QLD) - Saturday, Dec 16, 2006 at 09:40
LOL ........ thats only one name I call them LOL.
FollowupID: 470654
Reply By: troopyman - Friday, Dec 15, 2006 at 23:29
OR , have you ever noticed that if you take something to the tip , sure as bleep you could have used it the next day .
AnswerID: 210588
Reply By: Member - Andy Q (VIC) - Saturday, Dec 16, 2006 at 00:03
G'day,
Guys, you mean to say that after all the years of experience all of you have had( I have been reading your posts for over 3 years now) that none of you carry a ground sheet, for when you are caught out and doing that repair, you know the one that srings up the other side of nowhere.
I got to admit I'm very surprised
andy
AnswerID: 210594
Follow Up By: Member - Phil G (SA) - Saturday, Dec 16, 2006 at 08:38
Andy you're right. It took me about 25 years to work that one out. I have a couple of pieces of old awning canvas that have a heap of uses.
The other trick I learnt off my son is to put a towel on the table when taking stuff apart - nothing can roll off off
FollowupID: 470644
Follow Up By: Shaker - Saturday, Dec 16, 2006 at 23:23
I think you will find that the kinetic energy of the object in question, is directly related to the size of the groundsheet ........ plus 10%
FollowupID: 470748
Reply By: Eric from Cape York Connections - Saturday, Dec 16, 2006 at 08:49
I am a carpenter and was installing a very expensive lock and had to reverse the handing.
I had to pull apart the lock to do so remove 3 small grub screws and turn the lever over and put the screws back in.
As you do drop one small grub screw and as per usual it has gone for ever.
I was doing it on a table so I thought I was ok.
Any way had to drive to a supplier of the lock approx 60k round trip to get another one cost of grub screw $10.
Take my work boots of that night and the screw was in the top roll of my socks.
Bugger
All the best
Eric
AnswerID: 210625
Follow Up By: Muddy doe (SA) - Saturday, Dec 16, 2006 at 09:07
Hi Eric
LOL.........you have a spare now!
Cya
Mrs Doe
FollowupID: 470647
Reply By: Member - Willie , Epping .Syd. - Saturday, Dec 16, 2006 at 10:03
Anyone ever pulled a Penn overhead apart ?
PN.14 , an anti -reverse spring , was designed to launch itself into the air during re-assembly and land on the closest piece of multicoloured carpet . The importer used to order them from the Penn factory by the thousands .
One thing I always do when pulling anything apart , is to place everything in the order it came out . That does not stop them all going "SPRONG " sometimes and scattering across the room . There is a special law to describe that - something about bread falling !
Willie.
AnswerID: 210632
Reply By: bob&loz - Sunday, Dec 17, 2006 at 00:15
Used to work in a plant making styrene balls for filling bean bags and had to repair a small metering pump with spring loaded WHITE ceramic ball valves. You guessed it, dropped a ball on the floor covered in white bean bag filling and had to spend the next couple of hours on hands and knees gently blowing the floor till i found a ball that didn't move.
AnswerID: 210732
