ERPS Electronic rust prevention
I have searched the archives on the above subject, most of the comments are several years ago. I would like an opinion from some one that has had the system installed for several years.
Do They Work ??
Where is the best place to purchase this unit in Perth
What price are they
Are they easy to fit or do you need an expert to fit them
What are the fitting costs
Do they interfere with the HF radio
Do they interfere with the computer system of a 2006 T/D LC
How much battery power is used in say 24 hrs
Your feed back would be appreciated
Reply By: joc45 - Saturday, Dec 23, 2006 at 17:25
Hi George,
Check out this link.
Cheers, and Merry Xmas
Gerry
AnswerID: 211807
Follow Up By: Member - George (WA) - Saturday, Dec 23, 2006 at 17:38
Thanks Gerry, I think the article is about Cathodic "Zinc anode" protection mainly used in boats that are on the water full time. I am led to believe that ERPS is a different system. I will wait and see what others have to say.
Cheers and Merry X-Mas & a Happy New Year.
Drive carefully
FollowupID: 471978
Follow Up By: Kiwi Kia - Sunday, Dec 24, 2006 at 06:52
George, I think that if you read that item again you will note that it explains how and why the corrosion takes place. It also sugests that there are some items on the market that may not work. So, if you know the science then you can read a manufacturers publicity material and make an informed descision on the merits of the system being marketed.
FollowupID: 472032
Follow Up By: Member - Glenn D (NSW) - Tuesday, Dec 26, 2006 at 19:12
Hows it going George ,
Was involved in a disscussion about a week ago on this topic .
As Kiwi says , have a closer look at the link , Its written by Dr Karl .
I was paricularly interested in the part about these units being banned in the US ( thats got to set off warning bells ).
Glenn.
FollowupID: 472300
Follow Up By: joc45 - Tuesday, Dec 26, 2006 at 20:07
Hi George,
Further to my earlier post, some earlier devices were described as "electronic cathodic protection" or similar. I think this description has disappeared now. As Dr Karl states in the article, cathodic protection only works where moisture is involved and only at the point of galvanic contact. My experience with non-marine cathodic protection involved buried steel containers, which had zinc bars buried in the ground and wired back to the steel container. In this case, moisture in the ground completed the electrical circuit.
Having read the technical jargon of a couple of ERPS units which have patches with an applied voltage which spreads protective electrons in a field stretching some distance from the patch, I fail to see how the electron field can reach enclosed areas such as rocker panels, usually the area of much rust in vehicles. Back in the mid 1800's, Faraday showed that the interior of an enclosed metal container will be completely isolated from an external electric field, from which one can draw similar parallels with the rocker panel or other fully-enclosed body sections. Unless these are cut open and a patch inserted, then they will remain unprotected.
I have never owned one of these devices; my technical background has shied me away from their explanations, so I have never tested one. I did, though, own a bog-standard Mav for 12 years, which included a lot of beach runs, incl through salt water. Each time I washed the body and underside in a timely manner. The vehicle was still rust-free when I sold it. My current Patrol is nearly 7 years old, and despite beach runs, is still rust-free (had the door panels off recently to check). I put this down to modern vehicles being better primed and treated from new.
The only rust mod I have done to the Nissan is to spray some fish oil into the door panels, rocker panels and wherever I think rust might start.
I have found that the fish oil also seems to stop the spread of existing rust (I used it to some effect on a 70's Italian car I once owned, which you could hear rusting, if you stood perfectly still and listened)
Gerry
FollowupID: 472316
Follow Up By: GaryInOz (Vic) - Tuesday, Dec 26, 2006 at 20:50
Gotta love the old Alfa 33/Alfasuds.....
FollowupID: 472323
Follow Up By: Middle Jeff - Tuesday, Dec 26, 2006 at 21:05
I had a sud, stoped at a set of light went to go and the front suspension broke in half, still the most fun I ever hade in a car.
Have fun
Craig
FollowupID: 472327
Follow Up By: GaryInOz (Vic) - Tuesday, Dec 26, 2006 at 21:57
Funniest I heard was a guy that was sitting at a set of lights in a Sud, and felt (and saw) his car sink. Thinking he had a flat tyre he got out, only to find the floor pan and body behind the front seat had parted company across the width of the vehicle (think chainsaw attack to the floorpan and rocker panels...). The only thing holding the vehicle together was the upper part of the side panels and roof.
FollowupID: 472349
Follow Up By: joc45 - Wednesday, Dec 27, 2006 at 00:54
Actually, it was a Fiat BC-series 124 Sport. Not as bad as the Alfa Suds for rusting, but it still rusted. Fabulous car otherwise. Only sold it last year - had it since 71.
Memories......
FollowupID: 472397
Reply By: MartyB - Saturday, Dec 23, 2006 at 17:40
I bought one years ago, had it installed on a 1991 Jackaroo which I owned for the next 5 years. During that time the Jackaroo did plenty of trips to Fraser Island (breach driving). The Jackaroo never had any rust in it at all. I also looked after it, washing it properly when returning from the Island etc.
When I sold the Jackaroo I removed it and installed it on the 1994 Discovery I bought. It has been on the Disco for 3 years and it has no rust either.
Heaps of people will jump up and down and say the vehicles would not have rusted anyway and maybe they are right but I will keep using it.
Mine is the ERPS brand.
They are easy enough to fit if you are used to running wires through the vehicle.
No they don't interfere with the computer or radios.
They must draw bugger all power because they don't run the bettery down.
Marty.
AnswerID: 211809
Reply By: Member - Phantom (WA) - Sunday, Dec 24, 2006 at 08:33
Hi George,
We sell them at work and I beleive it is hard to prove or disprove their effectiveness. I dont have one as I have been told that they stuff up HF reception.
I am in Mandurah and can get you one really cheap if you want to wait til next year when I am back at work. They are easy to fit in about 20 mins with a good wiring job.
Merry Christmas,
Steve
AnswerID: 211860
Reply By: Member - David A (QLD) - Sunday, Dec 24, 2006 at 08:54
We have had ERPS on our "other" vehicles for the past 7 years or so, first on a VT commodore and now on a pulsar. No rust, but as mentioned above maybe they wouldn't have rusted anyway.
Their website from memory has a lot of testimonials from surf clubs etc which was a big selling point for me. I liked the way the ERPS covered all the metal parts, not just those that got sprayed by the black gooey stuff in traditional rustproofing.
We bought ours online from olbis.com.au
David
AnswerID: 211862
