points gap on fj 62
Submitted: Thursday, Dec 28, 2006 at 01:26
narrv
would any one know the points gap setting on petrol 3f motor,
also the timming mark on the fly wheel seems to be a bit tricky
as
well,should it be cleaned somehow while idling..??
thanks for any input
narrv
Reply By: barney rubble - Thursday, Dec 28, 2006 at 09:59
Gday narrv points gap in the old scale is about 21 thou as for the timing mark just gotta turn the motor by hand till ya find it then mark it with some white out or similar but from memory its a bastard to find Cheers
212284
Follow Up By: narrv - Friday, Dec 29, 2006 at 12:56
thanks barney
yeh i found two marks one drilled hole mark and below it was a line ..
I set the timing on the round mark , maybe i should advance it a bit for a bit
of extra get up and go..???
But she seems to be running good.
Driving it to
Carnarvon next week loaded up trailer etc,,,,on timing mark
or advance it a bit ?????
shes done 280 000 kms uses a little bit of oil on the open highway.
cheers for any input
narrv
472681
Reply By: Member - Shane D (QLD) - Thursday, Dec 28, 2006 at 15:19
socket on the power steering pump will turn motor so you can find the timing mark on the HARMONIC BALANCER. spot of liquid paper on Top Dead Centre mark will make setting timing easier next time
212307
Follow Up By: 666toy - Thursday, Dec 28, 2006 at 20:30
Its on the flywheel old mate with a 3f not on the balancer unlike most cars, right hand side there is a little window about level with the dizzy.
Gap is set @ 0.4-0.5mm but i suggest you check & adjust with a dwell meter.
hope this helps ..................666TOY
472598
Follow Up By: Member - Shane D (QLD) - Friday, Dec 29, 2006 at 21:41
YEP, thats right ,it is too, I will now take my foot out of my mouth and drink more JD
472712
Follow Up By: 666toy - Friday, Dec 29, 2006 at 21:44
have one for me too Shane lol
472714
