phone free wireless internet
Submitted: Friday, Dec 29, 2006 at 21:54
ThreadID: 40712 Views:2849 Replies:6 FollowUps:7
OK - I am sure you will all tell me this has been done to death - but a thorough search still hasn't revealed any usefull answers.
i want to connect to internet - NOT through a mobile (which i use for calls only - I thought that was what they were designed for!) on occasional weekends away.
Telstra offer thsi service but only on a 12 month contratc. I just want to pay as i go - or use.
PLease don't suggest global roaming (as Telstra did!) or dial up for broadband, I cannot carry 200 kms of phone wire everywhere!
Just need a simple service for the laptoip that I connect to internet wherever i am and pay for what I use.
Does it exist????
Reply By: MartyB - Friday, Dec 29, 2006 at 23:13
Andrew,
This is a quote from Telstra's site" Pay-As-You-Go Plan – Mobile Broadband
If you are a low volume Mobile Broadband data user and prefer to simply pay for what you use, the Pay-As-You-Go Mobile Broadband plan may be ideal."
The only network with decent broadband speeds through most of Australia, not just metro areas is NextG.
Simplest option would be to have a NextG handset & use it for internet as well as phone calls, but you seem to have an adversion to that. So have a look at the Telstra Turbo card.
No it will not work in the middle of the desert , but it will work perfectly in outback towns for example Quilpie.
from Marty.
AnswerID: 212468
Reply By: friar - Saturday, Dec 30, 2006 at 06:13
G/Day Andrew W this reply is on a laptop with next G wireless broadband,$29 a month plan for 10hrs,just got it up & running bigpond had to supply a external aerial that plugs in to your broadband card & with a little valcro tab attaches to the back top of screen , this was necessary for my location,but might not be needed in the future as next G progresses,you can get no contract plans, the reason I went on a plan I did not have to buy the card outright,it is built in to the plan, hope this makes sense, also the speed is much faster than the old broad band ADSL that I was using. Friar.
AnswerID: 212482
Follow Up By: Member - Andrew W (VIC) - Saturday, Dec 30, 2006 at 09:34
who is this with? I have rung Telstra 3 times and every time they tell me that wireless broadband is only available on a 12 month minimum contract. Am I asking the wrong questions??
FollowupID: 472750
Follow Up By: John R (SA) - Monday, Jan 01, 2007 at 21:09
Telstra is probably assuming you'll go on a contract & thereby pay off the NextG card over the course of the contract. They like to make these assumptions, or at least convince you that it's the only way to access their network.
If you buy the card outright, as with a mobile phone, you should be able to go directly on to a flexible deal.
I haven't done this yet, so I'm working on a bit of guess work.
FollowupID: 472986
Reply By: friar - Saturday, Dec 30, 2006 at 10:19
Andrew W I could be wrong about not having to go on contract ,but there is a casual plan, if possible go to telstra shop,I am sure they will be able to tell help you,as they sell the broad band cards off the shelf.Friar
AnswerID: 212491
Reply By: Chucky - Saturday, Dec 30, 2006 at 10:41
If you have a telstra mobile you can just log onto the bigpond wireless network and have it charged straight onto you mobile account.
I do this at airports all the time.
It does cost about $6 an hour but if it's only every now and then you log on then it's most likely worth it.
AnswerID: 212493
Follow Up By: Chucky - Saturday, Dec 30, 2006 at 18:19
I forgot to add that this only works if you have wireless capability already.
My laptop has wireless builtin so all I do is connect to the telstra wireless network and when I access the internet it diverts me to the accounts page where I enter my mobile number, I then get a sms from telstra with a authorisation number that I enter into the telstra bigpond webpage and then I have full intrenet access.
FollowupID: 472776
Reply By: Notso - Saturday, Dec 30, 2006 at 11:30
You can only get the wireless cards on a plan as far as I know, unless you buy the card outright, then go on a casual plan.
Your next G phone will give you broadband speeds and you can buy casual data plans for it on top of your phone plan.
I currently use my cdma and pay for the mobile timed access but for emails only. Shortly will go Next G, as soon as they can convince me that the access is as good as CDMA.
AnswerID: 212499
Follow Up By: disco1942 - Saturday, Dec 30, 2006 at 15:34
When you change over get a plan that includes 'My Hour.' That way you will get some 20 minute slots where you do not pay for time whilst transferring mail - works for me.
FollowupID: 472771
Reply By: Member - MrBitchi (QLD) - Sunday, Dec 31, 2006 at 09:26
Sounds like what you're after is Wi-Fi. Other replies all indicate using a mobile for access. You can get pure wireless access from places like Unwired or iBurst, which operates off a modem card plugged into your laptop but coverage is VERY limited. Fraid that the only practical solution is through your mobile ;-(
AnswerID: 212558
Follow Up By: Member - JohnR (Vic)&Moses - Tuesday, Jan 02, 2007 at 09:10
G'day John, hope you have a great year.
I agree with your thoughts on the question but Telstras answer is Next G doing the same thing. Think the questioner doesn't realise that the network will act as wireless spectrum internet access at the Telstra frequencies. Not using the normal Wi-Fi ones. The other options with Next G is to plug into your phone and use the phone as a modem.
FollowupID: 473016
Follow Up By: demented - Tuesday, Jan 02, 2007 at 15:32
john and john,
the NextG system with Telstra is available as a wi-fi equivalent for laptop that is not through the mobile phone, it uses a wi-fi style pc card. It is also available through a mobile phone, just to make things a little more complicated. So you can have the equivalent to the i-burst wi-fi roaming network but anywhere that Telstra has their broadband enabled mobile towers. It works just like the standard wi-fi local systems (at airports etc) as far as the user is concerned, but uses mobile phone frequencies and can roam beyond the local point where you logged on.
I hope that makes a bit of sense.
I looked into this one a bit myself recently for a friend and seriously considered it for myself except for the fact that the high volume download plans are a little expensive :(
Demented.
FollowupID: 473052
Follow Up By: Member - JohnR (Vic)&Moses - Tuesday, Jan 02, 2007 at 23:30
Yes, understand that Demented. Just used the same frequency and technology. The cards are throttled back to the speed paid for. I agree on the charging too but I can only get ISDN on my phone lines here so the Telstra monopoly charging may get me in! :-(
FollowupID: 473143
