To intercool or not to intercool?
Submitted: Thursday, Jan 04, 2007 at 20:55
Beadman
Going touring in a few months and would like to know if I should spend more money on the fourby in the way of an intercooler. I've put 4"
suspension lockers and a lot of thing you need for the terrain up there but I don't know if i need to spend more money installing an intercooler. I'm not mechanically minded i don't even know what an intercooler is. Can some one please help with this matter and if i need one can i get some specs and brands
Thanking you in advance
Reply By: ExplorOz Team - David - Thursday, Jan 04, 2007 at 21:05
Site Search or Topic Search are your friends on this topic see the following articles and pages on ExplorOz.
Intercoolers for Diesels
Servicing & Modifications
Good luck!
213286
Reply By: Truckster (Vic) - Thursday, Jan 04, 2007 at 23:54
>> put 4"
sounds like you walked into a 4wd store and they sold you the works.
Where is UP THERE?
do you have a turbo?
213325
Follow Up By: Beadman - Friday, Jan 05, 2007 at 07:16
CAPE YORK through the creb and OTL and yes I do have a turbo.
I've been 4wding (mostly Landcruiser
Park)for quite a few years. I'm a person that likes to be prepared for the worst especially with two kids under 4. I did a lot of shopping around for all my improvements but no one has yet said you need an intercooler or that an intercooler will make my fourby more reliable it's just something I've been reading in mags, but there all advertising their own coolers anyway by making them sound like you defenitly need one.
I just want the truth and nothing but the truth!
THX truckster
473655
Follow Up By: John Davies - Friday, Jan 05, 2007 at 09:42
An intercooler could possibly make your engine more reliable by running leaner, but if the turbo has been properly installed/tuned it is not required and really a waste of money. I would spend your money on a boost and EGT gauge instead.
I would also say that a 4"
suspension lift for long distance touring is more of a hinderance because of a raised centre of gravity. (more likely to roll over and less high speed stablity).
John D
473683
Follow Up By: Truckster (Vic) - Friday, Jan 05, 2007 at 10:06
I'd agree with JD on the lift being a PITA and going the gauges before anythign else
473698
Reply By: Ian from Thermoguard Instruments - Saturday, Jan 06, 2007 at 15:46
Hi Beadman,
A bit more info would help: What make and model vehicle? Factory or aftermarket turbo? Standard or 'tuned' for improved performance already? With this info we (i.e. the
Forum) might be able to give you a little more informed advice.
Ian
213656
Follow Up By: Beadman- Saturday, Jan 06, 2007 at 20:37
Sorry about that,
GU II 4.2TD Factory turbo - Standard
100,000 km
THX
474031
Follow Up By: Ian from Thermoguard Instruments - Sunday, Jan 07, 2007 at 09:41
Hi Beady,
I'd spend the money on something else. I think an intercooler alone on that engine would have minimal benefits. If you're happy with the power levels, leave it alone - it will be quite adequate for your
Cape York trip. If you're really after more power and torque there are other things I'd do first.
Apparently the standard turbo set-up on the TD42T engine is not the most efficient one around and there are a few mobs around that will modify the turbo and injection pump for quite improved performance - MTQ is one but I'm sure Denco and others would too. If you still want more grunt and have plenty of money to spend, then add the intercooler and have the pump re-tuned to suit.
I echo the comments of others on radical
suspension lifts (I regard anything over 2" as 'radical'). Unless done properly with castor corrections, modified panard/radius rods etc. etc. they can create steering and tyre wear problems. They also make the vehicle less stable cornering and on side slopes (especially the 95+% of the time most spend on the bitumen).
Ian
474079
Follow Up By: Beadman- Sunday, Jan 07, 2007 at 10:19
Thx for that info. You've settled that decision for me.
When I had the lift. I made sure , modified panard/radius rods, castor kit etc. were used. I didn't just use springs and shockies.
I done a lot of shopping around and come up with the best option for my situation I spent $3400 to make sure it was done properly
once again thx for your advice
474083
