1hz turbo oil
Submitted: Thursday, Jan 04, 2007 at 22:32
ThreadID: 40873 Views:3942 Replies:5 FollowUps:0
hi all ,
i have a 2002 hzj 105 turbo and intercooled wagon
and i m not sure what oil to use i usally change oil and filter every 5000 km its done around 10000 km since turbo cooler fitment i have chaged oil and use valvolene super desiel is this ok or is there something better
thanks bb
Reply By: Footloose - Thursday, Jan 04, 2007 at 23:25
Check out Caltex CXJ...not the CX3. hard to find but the recommended oil by many in the know AFAIK.
AnswerID: 213316
Reply By: Member - 'Lucy' - Thursday, Jan 04, 2007 at 23:54
Evening Black Bull
There are 5 steps to this exercise.
(1) Locate your HZJ105 owners manual.
(2) READ IT - in particular the section re service where it will identify the OEM recommended API and Viscosity specs for the oil to be used in your vehicle.
(3) Do a google/web search and establish what oil/s with the aforementioned specs are available to you in your area.
(4) Use your own mental accumen to then decide what oil brand you will use and from where you will purchase it.
(5) Then do it
Oil Filters - there is only one option for Toyotas and that is genuine ( If you want to avoid possible issues that is).
Reason being the OEM filter has a different valving system designed to hold oil for the next start.
AnswerID: 213324
Reply By: markeaust - Friday, Jan 05, 2007 at 12:09
I have the same truck minus the turbo 8-( I spent a great deal of time looking into this recently. It would appear that many recommend using any good quality 15w40 engine oil and there are numerous reports of engines doing 500k km with no issues.
For me, I decided to go with the "Japanese Diesel Engine Oils" as many others in the know recommended these oils as from what I can gather, there are only 2 specific oils that fit the criteria... Caltex CXJ and Castrol J-Max.
The other place to ask these questions is on the LCOOL yahoo group.
Only time and km will tell whether this is the right decision.
Hope this is of some help.
Mark
AnswerID: 213397
Reply By: 666toy - Friday, Jan 05, 2007 at 12:32
Nothing wrong With Valvoline super diesel oil & it is fine in your vehicle.
Have used it for years in my own trucks & 4x4 as well as in my workshop for customers.
AnswerID: 213403
Reply By: keepingitreal - Saturday, Jan 06, 2007 at 12:52
My 2 bobs worth. Aftermarket turbo 1hz, run Castrol RX Super, (Buy in bulk as used in heavy machinery), with Bitron engine additive. Change oil and filter (dont have to use genuine filters either) every 10,000km not 5,000 and i have absolutely no dramas. Oil stays quite clear for a long time! I do a lot of km's regularly at high temps usually pulling heavy trailers so turbo gets a good work out and performs fantasic. Regards Kirsten (NSW)
AnswerID: 213620
