ARB AirLocker leak??
Submitted: Friday, Jan 05, 2007 at 12:18
ThreadID: 40890 Views:3747 Replies:3 FollowUps:1
G'day,
When I switch on the compressor, it builds up pressure then powers off. OK so far. Then switch on the (rear) locker- activates solenoid OK but the compessor keeps pumping. Air coming out of diff. breather, and traces of HP (diff) oil around solenoid.
Obviously a seal gone- but where, and what's the go in repairs???
Reply By: Member - Drew T (Melbourne) - Friday, Jan 05, 2007 at 12:50
I had something similar on a recent trip where I was using the difflock a few times. Oil started appearing around the solenoid everytime I turned the solenoid off. I was told by local 4WD place that it means a seal/o-ring has partially failed in the difflock itself & the ARB fix is to instal a non-return valve in the airline (about $60 from memory). You could replace the failed o-ring but of course that would be far more expensive. btw .. have a look at www.stu-offroad.com/axle/arb/arb-9.htm
Don't know about your additional problem re continuous running of the air compressor .. perhaps the o-ring(s) are well & truly stuffed
AnswerID: 213409
Follow Up By: Member -Signman - Friday, Jan 05, 2007 at 13:07
Oh dear- then I guess this weekend is stuffed. I'll be under the vehicle gettin that 'orrible diff oil all over the place. I'll nick up to Moorebank this arvo and get some seal & o rings...
Whats the go on the non-return valve?? Might be worth trying before I get serious??
FollowupID: 473754
Reply By: cowpat - Friday, Jan 05, 2007 at 16:20
Before you pull everything to bits check that it's not the bulkhead fitting where the airline joins the internal copper pipe that is leaking. There's a little O-ring in there and it can leak so that the air goes into the diff housing but doesn't get outside. Crank it up a little and see if it fixes it. If not pull the bulkhead fitting apart and check the condition of that O-ring before pulling the whole diff carrier out. Casper
AnswerID: 213457
Reply By: donk - Friday, Jan 05, 2007 at 17:51
I don't know how old you diff locks are but on older vehicles the air delivery collar that sat over the end of the diff carrier had 2 parallel orings that ran on the diff carrier
What whould happen with usage is the metal diff carrier would wear on the surface where the orings ran (the same way that a pinion oil seal rubber lip will wear a track in metal diff flange)
I don't know if later air lockers still use this system to put air to the diff centre
I am not saying that this is what is wrong with yours but it may be & to fix this is a diff centre out job
Regards Don
AnswerID: 213479
