LC 100 roof rack
Submitted: Monday, Jan 15, 2007 at 03:37
bandk
Hello All
I thought I read something about guterless roof racks and sealing around the bolt holes and mounts to stop
water from leaking past them. Anyone had any experience with this one ?
Brad.
Reply By: Richard W (NSW) - Monday, Jan 15, 2007 at 07:05
Yep.
Mine originally leaked. I dipped the bolts in Silastic before replacing them. Its been fine since.
215359
Reply By: Peter 2 - Monday, Jan 15, 2007 at 12:27
Be very careful of weight and type of roofrack fitted as if the rack is too stiff or there is too much weight combined with outback travel then cracks develop in the roof which causes leaks as
215403
Reply By: Bilbo - Monday, Jan 15, 2007 at 19:04
The potential for leaks with a gutterless mount must be reduced by making sure you seal every bolt in the mountings and it's surroundings. If a reasonable amount of
water gets down inside the door pillars etc and wets even the door lock coils it creates havoc with the whole car electronic systems. It even sends the engine managemnet system crazy.
My mate left the bolts out compeletly on his 100 Series V8 'Cruiser when he removed his roof rack - he was "gonna put 'em back another day". It poured down the next day. It cost a fortune to sort the mess out. There were lights coming up on the dashnboard that he didn't even know he had!! It was like being inside a video game!!
I laughed but he didn't think it was funny at all,,,,,,,,,,,,,,so I laughed even more.
You had to be there!!
Bilbo
215496
Reply By: Member - Andrew W (SA) - Monday, Jan 15, 2007 at 20:10
Yep ... the
water comes down the A, B, C and D pillars ... if you don't seal the bolts.
I bought
mine with the leak ;-)
215512
Reply By: bandk - Monday, Jan 15, 2007 at 20:31
Thanks consider them sealed..
215527
Reply By: fozzy - Monday, Jan 15, 2007 at 20:32
bankk
had arb rack on/off lc100 for 3 years and no signs of leaking yet.
i make sure i use the thin washers that are OE with the bolts.
so far so good-maybe next time i take off will use silicon when putting back on.
hadnt heard of any problems in past
fozzy
215529
Reply By: Member - Jay L (QLD) - Tuesday, Jan 16, 2007 at 12:16
Use Sikaflex rather than normal silastic. It's the stuff used by manufacturer's and panel shops. It's available at Bunnings. A bit more expensive but its great stuff. It stores
well in the fridge.
215630
