Mould on Awning
Submitted: Monday, Jan 15, 2007 at 12:43
Dave Thomson
Hi Everyone,
anyone know how to remove mould spots from the under side of the awning ? I know theres stuff called magic awning cleaner but I've an idea that would be expensive as it's sold in the caravan shops any one know a way ?
thanks in advance,
Dave
Reply By: 4wdNewbie - Monday, Jan 15, 2007 at 12:49
We had a bit of mould on the carpeting in the house under a chair, we threw the chair out and used a heap of bi-carb soda on it. Cleaned it right up. Dunno it that will work outside, but i dont see why it wouldnt.
Anand.
215411
Reply By: gav99x - Monday, Jan 15, 2007 at 15:06
We've used Exit Mould (bathroom mould remover) successfully on canvas boat awnings, works very
well however the awnings are white - don't know what bleaching effect (if any) the Exit Mould would have on coloured material.
Might bleach it so maybe test on an inconspicuous area if you go down this path.
215444
Reply By: Member - Barry M (NSW) - Monday, Jan 15, 2007 at 16:15
Hi Dave, the childbride says sponge with white vinegar & adds that exposure
to
bright sunlight will kill the fungus. The lady only made one mistake so this
should work :)))....oldbaz.
215457
Reply By: Max - Sydney - Monday, Jan 15, 2007 at 18:41
Dave
We've had it a couple of times. Just waited till we had it out in a caravan
park (as we keep it in storage), got a bucket of hot
water and the cheapie
shop broom we keep for washing the van, and scrubbed it inside and out. Just used plain
water and the same broom to rinse. Then left it our to dry and put up with drops of
water in ears till it happened.
Dead set easy and no fancy chemicals.
Certainly rejected the idea of paying big money to caravan shops for the fancy stuff.
Max
215489
Reply By: Mr Fawlty - Monday, Jan 15, 2007 at 19:01
DO NOT USE BLEACH OF ANY DESCRIPTION ON PLASTIC AWNINGS.
Some car wash detergent applyed as suggested with a broom should do the trick, make sure you rinse and leave open to dry...
215495
