Petrol in diesel
Submitted: Thursday, Jan 18, 2007 at 23:06
Charlie1
Howdy all, I seem to remember a post awhile back about adding a small amount of petrol with the diesel in a diesel powered vehicle to increase performance, but I am damned if I can find it. Any comments and opinions would be appreciated.
Ta Charlie.
Reply By: Member - Tour Boy- Friday, Jan 19, 2007 at 06:31
Hi, I use 200-300ml of petrol to a full
tank of diesel every now and then to clean the injectors. Not purely for performance but does help a fraction.
Tour Boy
216304
Follow Up By: Member -Signman - Friday, Jan 19, 2007 at 09:32
Would the petrol 'mix' with the Diesel?? I dunno the relative viscositys of the two- but would the petrol float (or sink)??
476687
Reply By: Shaker - Friday, Jan 19, 2007 at 09:50
Amazing how it takes "up to a month for crude oil price drops to be seen at the pump" ........ yet increases appear the same day!
216345
Reply By: Tim HJ61 (WA) - Friday, Jan 19, 2007 at 09:54
I understand you can add a portion of petrol to diesel and it is used in winter to stop the diesel gelling. Something around 15% I think.
I used 15% petrol to thin a batch of veggie oil and all worked fine until the engine was hot and working towing a trailer. Then I got these nasty, very very nasty, noises coming from the engine. Like a deep growling noise and loss of power. My instal is not standard, nor my fuel mix, as I run a heat exchanger to heat the fuel - veggie oil - so this is not advice for anyone. What appears to have been happening is the petrol was igniting earlier than the oil and the flame fronts were colliding inside the chamber. This was a bad thing and I won't be doing it again. Engine had good power tho prior to this.
Short answer is yes you can add a bit of petrol. The proportion needs to be low, I'd take a punt at less than 10% following my experience, but you'd need a damn good reason to do it. My exhaust was noticeably hotter to touch, indicating higher internal temperatures which 'may' end up causing damage, or 'may' just be a result of the extra bang in the mix that gives more power.
Yes petrol does mix
well with diesel, try a bit in a suitable container and let it sit for a while and see what happens.
Short answer yes you can, suggestion is no you don't.
Tim
216347
Reply By: luch - Friday, Jan 19, 2007 at 09:54
Petro and Diesel mix
4 weeks ago
Friend of ours accidently put 85 litres of petrol into a 95 litre
tank in his 80 series landcruiser turbo Diesel
He got 14 kms down the road and it just stopped no warning, the symptoms were like air in the fuel system
He got it towed here so we could have a look not knowing what was wrong, went to bleed the fuel system and it smelt like petrol (checked his reciept and comfirmed it was) . Emptied the filter bleed the injectors and the fuel filter and started it on the Sub
tank ran a little rough for a minuite and back to normal
Since then he is getting better fuel economy.
Very lucky though my brother who is a Diesel mechanic said that petrol can make the injectors sieze as the petrol doesnt have enough lubricating qualitys
216348
Follow Up By: Member - MrBitchi (QLD) - Friday, Jan 19, 2007 at 12:02
Whats so different about diesel injectors to petrol injectors that would cause them to seize if petrol was used????
476733
Follow Up By: luch - Friday, Jan 19, 2007 at 12:09
Petrol injectors are electronic solinoid open and close
Diesel are mechanical and open under pressure they have tight tollerances inside therefore needing lubrication
476735
Follow Up By: luch - Friday, Jan 19, 2007 at 12:12
Forgot to mention this would happen if only petrol was used
a bit of petrol mixed into a full
tank of diesel wouldn't harm it
476736
Follow Up By: Member - MrBitchi (QLD) - Friday, Jan 19, 2007 at 12:30
AAhhhh ssooo ;-)
476744
Follow Up By: Kiwi Kia - Friday, Jan 19, 2007 at 20:10
I certainly would not deliberately mix any petrol with diesel. The petrol will detonate before the normal part of the cycle that diesel detonates. It's a good way to knock a hole in the top of a piston !
476900
