Toshiba 480CDT vs. D-Link DFE-690TXD
Submitted: Monday, Mar 31, 2003 at 15:33
ThreadID: 4142 Views:2258 Replies:4 FollowUps:0
Have tryed to install this NIC card many times using conflicting instructions from Micro soft and D-Link. Using Win98.
Want to use for GPS (Garmin Legend)
When checking control panel, and clicking on PCMCIA both slots show emty!
Reply By: BruceL - Monday, Mar 31, 2003 at 17:19
Don't know about the Toshiba but on my IBM T20 I needed to use the IBM setup utilities to 'enable' the PCMCIA slots before the system would recognise a card. Straight sailing after that.
AnswerID: 16512
Reply By: BruceL - Monday, Mar 31, 2003 at 17:21
Don't know about the Toshiba but on my IBM T20 I needed to use the IBM setup utilities to 'enable' the PCMCIA slots before the system would recognise a card. Straight sailing after that. I assume Win98 hasn't recognised new hardware PNP so you may have to use Control Panel to force a hardware refresh. If that doesn't work use Add Hardware/have disk and install your drivers that way.
AnswerID: 16513
Reply By: Peter - Tuesday, Apr 01, 2003 at 07:04
You may need to run some pcmcia card managment software to get it all happening.
Also check in settings that it can see the slots .
Maybe the slots are not activated.
AnswerID: 16556
Reply By: Robertez - Saturday, Apr 19, 2003 at 01:31
Thanks for the help, I found a Compaq 32 bit PCMCIA Ehternet card for $15.00 US. Installed it and adjusted setting as pointed out in responces. Now up and running in Maryland, using Garmin Legend GPS along with laptop. Can't wait to go to the shore and scout some 4x4 areas.
AnswerID: 17915
