charging battery
Submitted: Saturday, Jan 20, 2007 at 10:54
pjp65
I have a dual battery system that mainly runs a 60lt fridge. If i use a 1kw invertor generator through a battery charger do i have to disconnect everything to recharge battery or can i plug it straight on the terminals .Im not sure if i would harm the fridge or dual battery system if left connected.
Reply By: Robin - Saturday, Jan 20, 2007 at 11:01
Hi PjP65
Essentially you can just connect across the terminals from your battery charger without damage.
You don't say what sort of dual battery system you have , and depending on this it may or may not charge both batteries.
Robin Miller
216606
Reply By: Derek from Affordable Batteries & Radiators - Saturday, Jan 20, 2007 at 11:06
Hi pjp65
Yes just charge directly to the aux battery.
What size charger do you have ?
A 15 to 25 amp unit is a good size. Any smaller the generator will need to run 1/2 the day.
Derek.
216607
