Shovel Holders
Submitted: Saturday, Jan 20, 2007 at 12:59
ThreadID: 41426 Views:8506 Replies:14 FollowUps:11
Hi All,
Looking for ideas on mounting a long handled shovel to either the Patrol or camper.
My ideas are usually either extremely primitive and feeble or so highly sophisticated that they cost an arm and a leg to build (come on we have all experienced this haven't we?).
Anyone have any simple ideas for a strong mounting system that allows relatively easy removal and fitment of the shovel?
All replys are appreciated.
David
Reply By: Kev M (NSW) - Saturday, Jan 20, 2007 at 13:05
Why not get a roof rack attachment for it.
Kev
Russell Coight:
AnswerID: 216632
Reply By: hoyks - Saturday, Jan 20, 2007 at 13:05
a piece of pipe with a grub screw. Find a piece of pipe that will slip over the handle and drill a hole in it to fit a bolt to use as a grub screw. Weld on a nut to accept that bolt and you can also weld a small handle on the bolt head so it can be undone easily. How it attaches to the vehicle is up to you.
Real cheap option is an occy strap.
AnswerID: 216633
Follow Up By: Member - John and Val W (ACT) - Saturday, Jan 20, 2007 at 13:38
David,
Troopies have a pipe crossmember at the front of the chassis, right size and length to hold a shovel. I use it as hoyks suggests above. If you don't want to do a full upgrade to a Troopy, maybe you could find a place up front to attach hoyks' pipe. Works well.
HTH
J and V
- Albert Einstein
FollowupID: 477051
Reply By: Member - Phil G (SA) - Saturday, Jan 20, 2007 at 13:10
On the spare tyre is good.
On the Prado, I used 8mm bungy cord - loop on one end, hook on other. Loop end goes into itself around a wheel spoke, and the hook end goes once around the shovel handle and hooks onto a spoke on the other side.
The bungy cord keeps it tight. If you use 2 bungy cords it will never come off.
AnswerID: 216634
Follow Up By: Member - Phil G (SA) - Saturday, Jan 20, 2007 at 16:17
Found a photo:
!MPG:14!
FollowupID: 477069
Reply By: Member - Andrew (QLD) - Saturday, Jan 20, 2007 at 13:16
I've been thinking of mounting a shovel within the external frame of the floor of my Kimberley Kamper......that way it wouldn't be in the road when assembling the camper, yet still have quick access. Maybe you could do the same? ;-)
Andrew
AnswerID: 216637
Follow Up By: Member - Duncs - Saturday, Jan 20, 2007 at 16:44
The drawback with this idea is that when you go out for a daytrip from camp it is very easy to forget the shovel.
Here I am bogged in the sand and my shovel is neatly stowed on the camper back at camp!!!! Bugga!!
FollowupID: 477077
Reply By: Truckster (Vic) - Saturday, Jan 20, 2007 at 13:20
Something like this? You can see the quick release pin and bolt in the center of the wheel in this pic, so the shovel/axe all comes off in one piece if you need the spare tire.
You will have to paste these in, for some reason all images from my site wont come up here now.
http://www.gupatrol.com/pics/shovel/shovel1.jpg
http://www.gupatrol.com/pics/shovel/Shovel.jpg
AnswerID: 216638
Follow Up By: Member - Andrew (QLD) - Saturday, Jan 20, 2007 at 15:21
How would that set-up go with a long-handled shovel though?
Andrew
FollowupID: 477057
Follow Up By: Grungle - Saturday, Jan 20, 2007 at 15:52
New site truckster! I was thinking of taking gupatrol.com a couple of years ago but never got off my arse to register. Looks like I missed the boat.
I noticed that a link to my webpage is outdated (David Christensens GU Patrol). New link is
http://www.mcs.net.au/~grungle/
Looking forward to seeing it grow.
David
FollowupID: 477063
Follow Up By: Member - Phil G (SA) - Saturday, Jan 20, 2007 at 16:09
Trucky, doing flex shots at Warraweena.......check this out:
http://www.exploroz.com/Uploads/Members/Pic_41965.625_13.jpg
Hehehe
FollowupID: 477067
Follow Up By: Member - Duncs - Saturday, Jan 20, 2007 at 16:54
Truckster,
I used a similar set up on the GQ and am seriously considering going back to it.
Mine was simply a bracket that the blade of the shovel fits in. It hangs on the wheel and is curved to follow the tyre sidewall. The top of the spade is strapped to the wheel using an occy. It is quick simple light and easy to store when not in use. I'd take a piccy of it but I stored it somewhere safe. Then I moved house, twice.
I'll bet none of you can understand that. Clear as mud. Oh well.
Duncs.
FollowupID: 477080
Follow Up By: Truckster (Vic) - Saturday, Jan 20, 2007 at 21:50
na wouldnt work on long handled, but someone else mentioned it.
the only option for long handle is roofrack...
Phil.
yup, same spot Willem informed me it was comin up, was the first time I got to try the Konis out to see how they artic.. they were awesome on the property.
Dave.. I thought you would have grabbed it ages ago too! Still working on it at home, have a few pages of trips done.
Duncs, thats me, simple, and cheap..
FollowupID: 477155
Reply By: Andrew from Vivid Adventures - Saturday, Jan 20, 2007 at 13:23
I have mine on the side of the roof-rack in brackets that are readily available from roof-rack shops or the normal 4WD suppliers ... if you don't have a roof rack, you still need a shovel, of course.
The brackets I have hold both the shovel and the hi-lift jack.
One learning:
On the Telegraph Track down near Eyre Bird Observatory where things were pretty tight, I had a mulga branch hook onto the shovel, which had the blade at the back and literally tear it out of the brackets, bending the brackets on the way - if you find my shovel out there, please let me know and I'll pick it up ;-)
Now my shovel is mounted with the blade at the front for obvious reasons, and my bent brackets still work fine.
Shovel is readily accessible for digging out, toilet stops, campsite cleanup etcetera.
AnswerID: 216640
Reply By: Member - Willie , Epping .Syd. - Saturday, Jan 20, 2007 at 13:44
AHHHHHHHHHHHHHHH two oci straps on the roof rack .
AnswerID: 216643
Follow Up By: Eric from Cape York Connections - Saturday, Jan 20, 2007 at 14:44
I also only use an occy strap to locate it to the side of the roof rack and have done so for about 20 odd years.
Only on goings a new occy every couple of years.
All the best
Eric
FollowupID: 477056
Reply By: Darian (SA) - Saturday, Jan 20, 2007 at 18:07
On the spare, as Phil says, is hard to beat - no climbing to get it, out of the way and safe, cushioned mounting .... a design classic ! My Jack uses mags - there are 3 threaded holes in the centre for holding the chromed hub caps on. I drilled a hole thru the metal sleeve - in with a long bolt and wind it into the mag centre - pinch it up till the shovel bites on the tyre.
Er.... but.....now that I have my wheel cover back on, I'm up for a new design classic !
AnswerID: 216688
Reply By: mfewster - Saturday, Jan 20, 2007 at 18:54
If you have a roof rack..... TJM have some neat heavy rubber fittings that bolt on and hold all sorts of things with their own rubber closing strap that pulls down and clips over rubber teeth, About $6.00 each. Like a big rubber D with the vertical side of the D being the closure which tension grabs onto teeth at the bottom and can be adjusted for tension. I bolted a pair to the roofrack , but bolted them from the inside and left about an inch of bolt sticking out pointing away from the vehicle. Drilled a couple of holes in the shovel handle matching the length apart of the bolts, The shovel slides over the the bolts and is also held in place by the rubber ties. Very quick and easy to take shovel on and off and doubly secure becuase the shovel is held by the bolts to stop any backwards/forwards movement and the locking straps.
AnswerID: 216704
Reply By: Harry - Saturday, Jan 20, 2007 at 20:45
You can also fit onto the inside top of bullbar.
Mine is located underneath bullbar in pipe that is part of bullbar.
This is on a commercial bar by ARB for Troopy.
It wont fit on deluxe bars because of side wings on bar. (pipe is still there though)
AnswerID: 216719
Reply By: Leroy - Saturday, Jan 20, 2007 at 20:51
Check out this site. http://www.gupatrol.com/pics/shovel/shovel1.jpg and check out the shovel holder and the combo shovel/spade.
I have the shovel holder and have had no probs. I checked out the Brown Davis but it doesn't compare and BIL has had his crack twice in different locations.
Leroy
AnswerID: 216722
Follow Up By: Leroy - Saturday, Jan 20, 2007 at 22:05
I should take note of what I cut and paste eh!
www.4x4equip.com.au/4x4Equip/products.php
Leroy
FollowupID: 477157
Reply By: Member - Stan (VIC) - Saturday, Jan 20, 2007 at 20:58
I use axe & sovel holder
Link
AnswerID: 216726
Reply By: Member - Doug67 (NSW) - Saturday, Jan 20, 2007 at 21:36
Kaymar have a good one, combined with a highlift jack holder.http://www.kaymar.net/products/roofrack.htm#jack
AnswerID: 216741
Reply By: Member - Jeff H (QLD) - Sunday, Jan 21, 2007 at 01:48
Upgrade to a ute, and shove it in behind the 'mud guard'.
(May need to set a bolt at the lip position of the shovel.)
Cost , < $1
Access, 3secs.
AnswerID: 216779
Follow Up By: Member - Phil G (SA) - Sunday, Jan 21, 2007 at 10:22
I'm with you Jeff - that hole on the front of the chassis is the perfect shovel holder. I drilled a hole in the shovel, and an occy strap hook holds it tight.
FollowupID: 477235
