GPS-not receiving GPS data
Submitted: Tuesday, Jan 30, 2007 at 12:29
ThreadID: 41780 Views:2877 Replies:5 FollowUps:3
Currently running an ASUS A636N PDA/GPS with OziExplorer. Can access all maps ok, but when I try to run moving maps, it gives the message 'No data received from the GPS' Any ideas on why?
Reply By: Member - Toytruck (SA) - Tuesday, Jan 30, 2007 at 12:53
Morty,
check your configuration "GPS NMEA", in Ozi. Need to make sure all the baud rates etc are at the same setting.
Toytruck
AnswerID: 218576
Follow Up By: Member - Toytruck (SA) - Tuesday, Jan 30, 2007 at 12:56
should read,
"File/configuration/NMEA (GPS)
Toytruck
FollowupID: 478999
Follow Up By: Morty - Tuesday, Jan 30, 2007 at 19:10
Thanks for the help, saved me hours of frustration.
I finally got the thing to work, and you lead me to the solution.
The Comm's port had to be set to Com5 - sentence GPRMC
The program port to Com9, and the hardware port to Com 5, Baud rates to 4800.
I'm heading off-road tomorrow down to the coast to try out the topo maps.
Thanks again.
FollowupID: 479092
Reply By: Mad Dog - Vic - Tuesday, Jan 30, 2007 at 12:55
Have a look at the Oziexplorer configuration, could possibly be something not set correctly.
AnswerID: 218577
Reply By: Member - David (WA) - Tuesday, Jan 30, 2007 at 13:58
Hi Morty,
You also need to set your GPS to send Nmea. This is usually done in the config or interface parts of your GPS.
David
AnswerID: 218588
Reply By: Im.away - Tuesday, Jan 30, 2007 at 14:04
You can use Hyperterminal (which is included in Windows) to see if data is comin in from the GPS. Don't forget that unless your GPS is receiving satellite data non will be shown so (and I'm not trying to be patronising here) make sure the GPS is outside.
Set Hyperterminal to the baud rate that your GPS says it is working at. Select the comms port that the GPS is working through set the other bumph to none,8,1 and then watch the screen.
If you are getting lines of GPS "sentences" (NMEA data) then the GPS is OK. From there it is simply a matter of checking that the GPS settings in OziExplorer match those you set to make Hyperterminal work. (Don't forget to stop Hyperterminal before trying OziExplorer.)
4800 Baud is fast enough for most purposes so see if you can set the GPS and OziExplorer to it.
Click Start NMEA communications with GPS (under the Moving Map menu).
Under Moving Map you can also click "Show NMEA input and output" and you should see the same sentences as you did in Hyperterminal. If so, Moving Map should work.
AnswerID: 218591
Follow Up By: Im.away - Tuesday, Jan 30, 2007 at 14:37
Oops, you might not have hyperterminal in your PDA, but you should still be able to use the "show NMEA input and output" to see if the comms are working.
FollowupID: 479029
Reply By: Nick R - Tuesday, Jan 30, 2007 at 22:19
Try resetting the PDA, usually works for me, Dell axim x50v
NickR
Carpe Cerevisi
AnswerID: 218725
