Who tows a van with a Troopy?
Submitted: Friday, Feb 02, 2007 at 22:25
ThreadID: 41915 Views:3555 Replies:7 FollowUps:5
Looking for some towing mirrors for the Troopy and it's not as easy as I thought.
The Ora strap on type weigh the mirrors down too much and they move out of
position after about 80kms/hr.
Anyone tried fitting the bigger, wider 79 series mirrors. Toyota can't tell me if they'll bolt straight on. The 79's have a welded nut inside the doors for the bottom part of the bracket, do the Troopies?
Any other ideas? Finding it difficult to get anything that works.
Thks
Reply By: Member - Doug T (W.A) - Saturday, Feb 03, 2007 at 00:49
I do ....when I do which is not often but my mirrors are not standard ones. but I use a little extension mirror that kinda looks like a scissor arms on it and it sits really good
Just had a look at it and there is no name on it other than US.pat.Product and a number but it is a little ripper I got in a Repco store
OK I found a pic on the web for you , go to this link and match up the serial No , 5th mirror down in the mirrors
www.camec.com.au/01-Car%20Accessories.htm
4 x 4 STRAP-ON REAR VISION MIRROR
The 4 x 4 mirror features an extra adjustment knuckle to allow fitting to larger vehicle mirror
heads.
0136-012
Replacement parts
0140-301-06 Strap
0140-301-11 Buckle
AnswerID: 219385
Follow Up By: RovingOz (QLD) - Saturday, Feb 03, 2007 at 09:05
Thks for that Doug.
I might try those because they would be fairly light and might not effect the position of the mirror too much at speed. Do yours keep their position?
Even though they don't get a good wrap I think it might he way to go. Cheap enough to replace every year or so if they deteriorate or disappear.
Anything I use will vibrate even the 79 trayback mirrors are apparently bad for this.
FollowupID: 479939
Reply By: Member - Phillip S (WA) - Saturday, Feb 03, 2007 at 01:19
Hi John....I installed a camera on the rear of mine which I use all the time (don't know what I ever did without it) and the screen is the size of a rear view mirror and goes in the same place...for towng a caravan I have a second camera which goes on the caravan and it is absolutely brilliant. saves so much grief I can tell you.
The one on the troopy is so usefull in shopping centres etc and I have the cofidence to go anywhere and know that I can park, reverse, etc with ease with no danger with people or cars or whatever....I have dark curtains all around so the camera is essential I also have those convex mirrors stuck on my own side mirrors to give me greater vision....it all works very well....you can see them at 4wd shows and a car and caravan package can be purchased for about $400-$500 and comes as a kit....regards Phil
AnswerID: 219387
Follow Up By: RovingOz (QLD) - Saturday, Feb 03, 2007 at 08:58
Hi Phillip
We also have that same camera setup.
I've been told you still need towing mirrors even with cameras. I tend to agree because you still need to see traffic down either side of the van when mobile. Also if the camera dies you need the back up.
FollowupID: 479937
Reply By: V8 Troopie - Saturday, Feb 03, 2007 at 01:27
I tow a 2.5m wide boat with my troopie and towing mirrors had been a problerm until I came up with this idea.
I made a bracket ( out of an old metal tent pole) and screwed it to the metal tube snorkel. On the upper end is a mirror with a swivel mount. The mirror is far enough forward to clear the opened driver door frame and gives a good view back.
When not in use the screw holes just have the screws minus the bracket.
This idea possibly wont work with the newer plastic snorkels.
The rubber strap add on towing mirrors are useless on a troopie, they vibrate far too much at any speed other than crawling.
Klaus
AnswerID: 219388
Follow Up By: Member - Doug T (W.A) - Saturday, Feb 03, 2007 at 09:11
The rubber strap mirror I used was perfect , did not even move when buffeted by on coming trucks, I will do a photo and later after breaky and put it on my 4x4 webpage , about 2 hours time
members.westnet.com.au/dtilley/4X4.htm
Doug
FollowupID: 479940
Follow Up By: Member - Doug T (W.A) - Saturday, Feb 03, 2007 at 11:04
Did you put a Patent on it , ,I forgot to tell the other post too that my mirror frams are same used on the Traybacks, put them on myself, the top screws on where the standaeds come off, just had to make a hole for the bottom .
FollowupID: 479960
Reply By: Member - Doug T (W.A) - Saturday, Feb 03, 2007 at 10:17
Ihave put the photo's on top of the webpage, still not had breaky though, after lunch I will take them off again , let me know when you have seen them .
Doug
AnswerID: 219422
Follow Up By: RovingOz (QLD) - Saturday, Feb 03, 2007 at 10:56
Thanks mate
Had a look. My mirrors are different. They're the smaller black mirrors on the 78s.
Thanks anyway. Appreciate it.
FollowupID: 479959
Reply By: Member - Boo Boo (NSW) - Saturday, Feb 03, 2007 at 15:04
RovingOz
I have a troopy and a while back bought a pair of extension mirrors from maytow in SAust. They cost an arm and a leg.
They attach to the bullbar and simply extend out to the desired width and height.
Like others I now use a camera and only occassionally look at the mirrors.
Regards Boo Boo
AnswerID: 219456
Reply By: Members - Bow - Sunday, Feb 04, 2007 at 22:02
Aussie truck mirrors are the way to go,as solid as a rock. You can buy them at CAMEC if you have a pocket full of money
The only problems are the mirrors are a bit on the small side.
They are hard to fit if you have Shields on your windows.
I could not do without my camera. When reversing the Caravan SWMBO walks behind the caravan and i can see her signals as well any obstacles. Saves a lot of arguments
AnswerID: 219766
Reply By: Gob & Denny - Monday, Feb 05, 2007 at 14:31
goodday all
mate and i built our own after having seen a couple of sets while travelling up north
they mount on the bull bar and extend out and have a small truck mirror on them they attach to the b/b with exhaust brackets and have very little movement but i am also installing a camera on the van so i can see directly behind the van as it doesnt matter what yuo use there is still a blind spot
steve
AnswerID: 219892
