2001 Rodeo
Submitted: Saturday, Feb 03, 2007 at 12:06
ThreadID: 41924 Views:2125 Replies:2 FollowUps:2
Any Rodeo nuts out there?!
Just bought my missus a 2001 rodeo dual cab V6, the one with the headlights that are flush with the grille. There doesnt seem to be any headlight adjustment, unlike the previous models with the square headlights. At the moment, low beam shines about 2 meters in front of the car, while high isnt much better!
Any help would be appreciated
Reply By: mike w (WA) - Saturday, Feb 03, 2007 at 21:15
Hello,
my name is mike and Im a rodeo owner...he he
as to your headlight quandry, If memory serves me correctly, if you look at the headlight from the front i.e. look at the lens, you will see a series of phillips head screws around the outside of the lens (recessed back behind shrouding) These my friend, are what you need to use to adjust your headlights.
Good luck
AnswerID: 219532
Follow Up By: mrdesmo - Saturday, Feb 03, 2007 at 23:15
Nice pic Mike....can't say I've ever seen a Rodeo at that angle!
Thanks for the tip, I'll have a proper look in the morning, was trying to adjust on the way home the other night, but had no luck in the dark!
FollowupID: 480109
Reply By: Graham & Lynne - Saturday, Feb 03, 2007 at 21:24
make sure bulbs are in correctly only fit oneway' but can be forced in two alternate position.
AnswerID: 219533
Follow Up By: mrdesmo - Saturday, Feb 03, 2007 at 23:16
No worries, will check it all out
FollowupID: 480110
