Camper trailer jacks
Submitted: Saturday, Feb 03, 2007 at 16:31
ThreadID: 41930 Views:5537 Replies:7 FollowUps:1
Afternoon all...
Just after a bit of advice on camper trailer legs...
I need to replace the stabalizing legs on the back of the camper and would like to up grade them to a leg capable of "jacking" the camper , not just stabalize it. The question is .... does any one know whats available and where to get hold of them.
Thanks,
Boo
Reply By: Member - jeff M (SA) - Saturday, Feb 03, 2007 at 17:32
Can't help you Boo,
But I would also like to know what's available.
AnswerID: 219471
Reply By: Outnabout David (SA) - Saturday, Feb 03, 2007 at 18:20
Mybe these would do the trick. Agricultural implement jacks which I have seen on someones trailer. Might be Mr and Mrs Al's.
www.bareco.com.au/files/general/g62a.htm
If you cant source them MM me as where I work is a distributor.
David
AnswerID: 219485
Reply By: JJ - Saturday, Feb 03, 2007 at 18:58
There's also 'Stak-a-jak's'. About $25 each from most caravan/camping shops.
AnswerID: 219497
Reply By: AdrianLR (VIC) - Saturday, Feb 03, 2007 at 22:10
Be very careful "jacking". Depending on the style of your camper, it's easy to warp the chassis with consequent problems ranging from just annoying (door/hatches not shutting) to real damage such as creased panels. The stabilisers are usually just that - only stabilise. You get the levels right by using ramps or digging a hole under one wheel.
Adrian
AnswerID: 219546
Reply By: Brian B (Brisbane) - Sunday, Feb 04, 2007 at 00:39
Boo,
CLICK HERE and you should find something.
AnswerID: 219568
Reply By: Ken - Sunday, Feb 04, 2007 at 12:35
Look for Alco [?] drop down jacks. Best by a mile, no dumb screw driving a pivoting arm to get clogged with mud/dust etc. Could easily lift a camper as it works on a rack & pinion but you may need to watch the twisting effect as noted in another reply.
Ken
AnswerID: 219635
Follow Up By: Member - Boo (ACT) - Sunday, Feb 04, 2007 at 12:43
Thanks Ken,
Have located a website that has some which look like they might do the job.
Here is the web address:
http://www.alko.com.au/vehicle/brochure/documents/AL-KOCornerSteady.pdf
Regards,
Boo
FollowupID: 480203
Reply By: Ken - Sunday, Feb 04, 2007 at 15:05
Yep, they are the ones !
Ken
AnswerID: 219678
