SHMBO wants her lights on and I can't find the fuse !!!
Submitted: Sunday, Feb 04, 2007 at 15:41
ThreadID: 41967 Views:2310 Replies:4 FollowUps:4
The car in question is a 2003 corolla station wagon and the lights on the gear shift (ie PRN123) are not working. I think I have pulled out every fuse inside and above the glove box and inside the engine compartment but can't find a blown fuse.
Any polite suggestions on how I can fix the problem for my little darling.
Regards Boo Boo
Reply By: herkman - Sunday, Feb 04, 2007 at 15:54
Isuspect the problem is not the fuse, but a miserable globe that needs changing.
Col
AnswerID: 219687
Follow Up By: Member - Boo Boo (NSW) - Sunday, Feb 04, 2007 at 15:58
Thanks Col I'll go and rip one of the panels off and have a look.
FollowupID: 480249
Follow Up By: Member - Boo Boo (NSW) - Sunday, Feb 04, 2007 at 16:22
OK Col,
I have just spent 10 minutes trying to get the facia/panel off, but no luck, do you know any way I can get it off without damage.
Thanks Boo Boo
FollowupID: 480256
Reply By: Voxson - Sunday, Feb 04, 2007 at 17:20
Tell the service guys at Toyota about it at the next service..
They know how to remove things quickly without breaking stuff...
It it was a fuse other things would stop working also..
AnswerID: 219704
Follow Up By: Member - Boo Boo (NSW) - Sunday, Feb 04, 2007 at 18:32
Thanks Voxson
After another go at it I think you're right.
Regards Boo Boo
FollowupID: 480273
Reply By: rags - Sunday, Feb 04, 2007 at 22:38
Boo Boo
Had a similar problem with our 2003 Corolla Levin wagon, where the clock light failed.In replacing this globe i had to first remove the panel around the auto stick which was as simple as opening and removing the bottom tray door on the centre of the dash then putting hand under the front edge of the the concerned panel and working the clips undone,this then allowed me to then unclip the centre dashpanel,i can't remember any screws whilst doing this .Theglobe for the clock was about $5.00 from toyota.
Now if only i could work out getting to the globe behind the DRIVE indicator on the instrument panel on our 90s PRADO.
Hope this helps
Russell
AnswerID: 219776
Follow Up By: Member - Boo Boo (NSW) - Monday, Feb 05, 2007 at 10:39
Rags
I might have a go your way, although the problem is in the consol between the seats.
It might be easier to pull s side panel out.
Although I now have to figure out what fuse I have put baxk in the wrong place as the blinkers don't work now, never a dull moment around here.
Regards Boo Boo
FollowupID: 480422
Reply By: Graham & Lynne - Tuesday, Feb 06, 2007 at 23:14
reconnect hazard switch or turn it on & off blinkers may work again
AnswerID: 220280
