Voxson - a Q re My Rig photos for state comp
Submitted: Thursday, Apr 03, 2003 at 08:09
ThreadID: 4199 Views:1795 Replies:7 FollowUps:1
Voxson,
I recall that recently you were able to help a bloke resize a pic for inclusion on the MY RIG section.
To help us - SA- win, I wish to insert the only pic I have on my PC. Trouble is , it's huge. 1.34MB, I think. Michelle Jacka says it can only be 50 KB.
Can you advise me on how to reduce the file size?
I have Adobe Illustrator 10, ArcSoft Photo Studio 2000 & MGI Photo Suite 8.06 on my PC
You may wish to hit me off line at rmoore@iprimus.com.au. - & that way the interstaters won't get any advantage of your local knowledge.
Thanks in advanceRick (S.A.) - dreaming & planning are half the fun.....doing isn't so bad either!
Reply By: Member - Willem- Thursday, Apr 03, 2003 at 10:20
Rick, Try saving your photo in JPEG format. This should reduce the size of the pic. Go to FILE, click on Save As. A dialog box should appear at the bottom of the window with bitmap, jpg, jpeg or others in it. Click on JPEG and then click Save. Should work. Hey, I am only a novice at this.Cheers, Willem
Never a dull moment
AnswerID: 16764
Follow Up By: Member - Rick - Thursday, Apr 03, 2003 at 17:46
Thanks Willem,
would not have thought of that. Trouble is, it's already Jpeg. Good try anyhow.
CheersRick (S.A.) - dreaming & planning are half the fun.....doing isn't so bad either!
FollowupID: 10409
Reply By: Member - Glenn(VIC) - Thursday, Apr 03, 2003 at 13:04
Rick,
In the interests of 4wd comradery, if you email the picture to me, I will attempt to reduce it for you....glennamarshall@iprimus.com.auJust Do It!
AnswerID: 16777
Reply By: Member -BJ - Thursday, Apr 03, 2003 at 18:30
Rick
Open photo in one photo suite and change resalution to 300 dots & it will reduce the file size . I had same problem with my rig photo
AnswerID: 16809
Reply By: Member -BJ - Thursday, Apr 03, 2003 at 18:41
Sorry rick should have been resize to 300 pixels
AnswerID: 16812
Reply By: Voxson (Adelaide) - Thursday, Apr 03, 2003 at 21:34
Hi Rick... I have emailed you...._____________________________________________
Countin the days till July 5th. *Cape York Trip*
AnswerID: 16824
Reply By: Member - Rick - Thursday, Apr 03, 2003 at 22:51
Thankx all for your helpRick (S.A.) - dreaming & planning are half the fun.....doing isn't so bad either!
AnswerID: 16836
Reply By: Truckster - Friday, Apr 04, 2003 at 17:54
Goto http://kickme.to/fosi/
Download and install THUMBS + Reboot puter.
Open Thumbs, and then Open the image with Thumbs + and press R. You will see in this window the size of your image, change it to what you like and save. When you save it gives options of compression 4:1 on image....
Thats what I use.
AnswerID: 16888
