ARB roof rack height/ 120 Prado
Submitted: Monday, Feb 05, 2007 at 17:29
Member - Mike_L (SA)
Hey guys,
Can anyone tell me how much height an ARB full length roof rack adds to a 120 series Prado?
Mick
Reply By: Muddy doe (SA) - Monday, Feb 05, 2007 at 18:10
I have this rack on
mine and it adds about 210mm to the highest part of the roofline which is over the small panel in the second row doors.
Mine is stock
suspension and is 2020mm to the top of the rack and 1910mm to the mighest point of roofline.
Hope it helps
Muddy
219947
Follow Up By: Member - Mike_L (SA) - Monday, Feb 05, 2007 at 18:37
Hmmmm....bad news for me, roller door is only 2030 high and I have raised
suspension....
Looks like I will be modifying the garage door!
Thanx Muddy.
480536
Follow Up By: GaryInOz (Vic) - Tuesday, Feb 06, 2007 at 00:46
Dig some wheel ruts ;-)
480642
Reply By: Member - Phil G (SA) - Monday, Feb 05, 2007 at 22:10
Mike,
ARB racks are all steel and very heavy. Try picking one up.
You may want to consider a flat platform rack - call in at Opposite Lock at Mile End - I think they stock a flat platform type rack that may go easily under your door.
I've always made my own racks, and find a flat platform to be a lot easier than one with sides - you can slide stuff up there a lot easier.
220040
Follow Up By: Member - Mike_L (SA) - Tuesday, Feb 06, 2007 at 21:08
Thanks Phil, Just looked at Opposite Lock's website. They do stock one, only 22kg too, must try and get down there this week to have a look.
480805
Follow Up By: Member - Phil G (SA) - Tuesday, Feb 06, 2007 at 21:14
Mike,
They are a good guys at opposite lock. ( But i guess I've found most 4wd shops in
Adelaide to be good). But Opposite Lock usually stock some alternative stuff that the bigger boys don't have.
480807
Reply By: Member - Shane D (QLD) - Tuesday, Feb 06, 2007 at 20:42
Mike'
I also have a rack from opposite lock and far prefer the flat plain(see rigpics)
there are a number of specific attachments that can be used for
wheels, shovels, hi lift jacks, gas cylinders, as
well as adjustable "eyes" for ropes or ockie straps
it's also longer than the arb.I only needed
mine for the tent but now I've got it i'm glad I did
Only prob is it was also one of the dearest,but it has detachable legs and can be interchanged with other vehicles
Shane
220243
Follow Up By: Member - Mike_L (SA) - Tuesday, Feb 06, 2007 at 21:11
Thank's. Will try and take a look at one this week.
480806
